| Forge Motorsport Manufacturers of VAG Turbo tuning accesories Custom build intercoolers , Diverter valves , Blow off valves , Forge Silicon Hoses by siliconhoses.com |
Thread Tools | Rate Thread | Display Modes |
#1 |
Hi!
I've recently bought an FMDV004 to my LCR225. After installing it, I didn't have no fault codes, but on a test drive the car felt like if it had only 130-140 HP, I think I have lost the pressure even on lower revs... Besides that, there were no sound at all. My car is totally stock, no engine upgrades, nothing.I know that the valve came with the blue spring by default, do I need to change to the red one? Or if I don't, what should I do? ![]() I would be really happy if you could help me. |
#2 |
Forge Motorsport
Hi the FMDV004 does not work on the 1.8T engine
You will need a FMCL007P or a FMDVSPLTR here are the links http://www.forgemotorsport.co.uk/con...oduct=FMCL007P http://www.forgemotorsport.co.uk/con...duct=FMDVSPLTR
__________________
#3 | |
Quote:
If the valve does not work on VAG 1.8T engines, why do a lot of people use them without any issues? I'm just curious, I've made choice after researching the Hungarian web, almost every site says this is the best option. Unfortunately I've picked the wrong model, but I don't think it is possible to trade in for a different one. ![]() If I want the sound of the releasing air as well, which one do I have to choose? The FMCL007P says: "keeping external noise to a minimum". What does "minimum" mean in this case?
#4 |
Forge Motorsport
The FMDV004 has been known to work with some of the earlier golf's due to different engine specs.
If you want the noise use an open cone filter and the FMCL007P
__________________
#5 | |
Quote:
![]() There's no other possibility than the open cone filter? I'm a little bit afraid of those things, I've heard a lot of bad rumors about them.
#6 |
Fortunately the seller takes back my FMDV004.
I think I'd go for the FMDVSPLTR because I'm looking for the "whoosh" sound when I lift off the throttle. I've searched the forums, many users said the FMCPL007 has almost no noise. I hope the splitter would work without any ECU fault codes. ![]() Do you think that it's enough if I use only a panel filter instead of a cone filter? I'm asking this because I already have a K&N panel filter on the shelf, planning to refit it to my car after cleaning it. ![]() By the way, thanks for all the help! |
#7 |
Forge Motorsport
With an open cone filter you will get lots of noise with the oem air box its near silent with the 007P
The split r will make noise with or without an open cone
__________________
#8 | |
Quote:
What setting do you recommend for the spring? How many clicks? I'm running on stock setup, no remap... yet. ![]() I'm refitting my K&N panel filter tonight/tomorrow, I wonder if I'll notice any difference...
#9 |
I've installed the splitter, but I'm a little bit confused. If I set the spring rate to 17 clicks, it's fine when I'm just cruising in town (even if I accelerate hard), but on the motorway I end up in limp mode after 20-30 minutes. What should I do?
#10 |
Forge Motorsport
Have you raised your boost pressure at all or have a remap?
__________________
#11 |
#12 |
16 clicks doesn't work as well.
Do I have to go under 14?
#13 |
I went down to 12, still no improvement.
#14 |
I've tried the upper range, 22 clicks, no luck.
Looks like I've lost in the limp mode lottery.
#15 |
Forge Motorsport
Maybe your car has a map please try 26 clicks
__________________
#16 |
I'm now at 24 clicks, no chatter, only a whoosh sound, but I couldn't manage to try it enough to say it's fine (limp mode occurs after 5-10 minutes).
If this doesn't work as well, what should I do? If I use it in full recirculating mode, basically I get a 007P? Or do you recommend to switch to that in that case? |
#17 |
Limp mode with 26 clicks. Besides that, I've got a huge boost lag between 2000 and 3000 RPM.
#18 |
Forge Motorsport
Can i ask how you have the valve fitted a picture would be great.
__________________
#19 |
#20 |
Now I'm using it in full recirc mode, but I don't now if I get the same performance as I would get with a 007P.
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
(View-All)
Members who have read this thread : 55
| 8bit, abs111, Allan_84, bbsboy, belfastchris45, Bogwoppit, Cammy, charlie boy, Ciosmi, Crafoo, Cupra Tommy, cupra_r_ick, czaki, dalegolf215, Dan Cupra R, Dani_b19, demisegr, DGF264, Dmoe, DOLBY, ferooo, FLK, ForgeMotorsport, gavyn g, george_seamons, ianmessy, ibizajamie, JonnyH10, Kris@Forge, leoncupra2012, Loorcepap, matt-tsi, Mick288, mr_bod, Muckipup, nd-photo.nl, Oj 89, Peter 87, pricey_2k10, rosshutchie, Scottage, seat chick, seatcupramad23, shnazzle, sjec, spen, Spirit Furtive, steady_eddy, Steely, Tucker157, turboboy111, welshlee cupra, will130787, x_jago_x |
| Thread Tools | |
| Display Modes | Rate This Thread |
