Formula One Brighton
SEAT Cupra.net - SEAT Forum » Diagnostics, Tuning and Modification » Engine Tuning » Samco TIP Vs metal type
Engine Tuning Discussion on all aspects of tuning and tuning products.
Reply
Old 13-05-2004, 14:03   #1
RobDon
Senior member
RobDon's Avatar
Pretty much every tuned 1.8T I see uses the Samco intake pipe between the MAF and turbo, hardly anyone seems to use the metal ABD or Neuspeed type. Why is this? Is it because the rubber top half can collapse under high boost (and looks kak too) and that the Samco is one smooth pipe? Also, the metal type bolts onto the turbo but the Samco is just a push fit and jubilee clip.
I currently use the Neuspeed TIP but I've bought a Samco one to try out, mainly for the above reasons (one smooth pipe, reinforced so won't collapse, looks better)
Any thoughts, pros and cons?
__________________
317bhp - CR Turbos hybrid power.
RobDon is online now   Reply With Quote
Old 13-05-2004, 14:16   #2
slim_boy_fat
Posts: n/a
THe samco makes the car sound like Darth Vader...
Old 13-05-2004, 14:21   #3
RobDon
Senior member
RobDon's Avatar
So do the metal ones, in fact some say because the Samco is thick 4/5-ply silicon, it's quieter that the metal/rubber combo. I'll know for sure once my Samco is on! In fact, I'll do vid clips before and after so we can all hear it.
__________________
Old 14-05-2004, 15:04   #4
ANDY BLUNT
Senior Member
ANDY BLUNT's Avatar
Fitting samco tip this weekend whilest changing turbo,we shall see then. Andy
__________________
A3 1.8T Quattro Sport,250bhp 290ish lbft Revo'd ST2,SPS3,Carbonio CAI,Forge DV006,KO3S ,Denso plugs,Samco tip,S3 Milltek and custom 2.5"downpipe 100 cell cat,FMIC ,S3 braces,R32arbs,Bilsteins,H&R springs,forge adjustable rear arms,S3 front wishbones(for more camber),6 spd box, Brembos.TT rims .
ANDY BLUNT is offline   Reply With Quote
Old 14-05-2004, 15:21   #5
LEO LION R
if you need to ask . . .
LEO LION R's Avatar
The Samco one is beter suited to the KO4 IMHO, as it has smoother bends and you don't need to bolt it directly to the turbo like you did on the KO3 - hence why the Samco one isn't so popular with the KO3 owners.
The Samco one is possibly smoother internally at the various pipe connections, but apart from that not a lot of difference, and i certainly haven't had any feeling of pipe getting deformed - it is still prety solid when warm.
P.S. I'll stand corrected if i'm wrong of the above
__________________
gone black LCR but not forgotten
LEO LION R is offline   Reply With Quote
Old 15-05-2004, 09:02   #6
Shock_Xe
Posts: n/a
Dont make em for ibiza's which is a shame
Old 08-06-2004, 12:20   #7
Yumann
Yumann's Avatar
I was under the impression that the car had 2 Tips? One that bolts directly to the turbo which is metal hence the neuspeed and abd metal ones. And then the samco silicone TIP which connects to the metal TIP? So there is 2 pipes one metal intermediate one and one samco one?
__________________
Leon Cupra R +
Yumann is offline   Reply With Quote
Old 08-06-2004, 12:25   #8
CupraR-Rog
Just Cruising...
CupraR-Rog's Avatar
Quote:
The only way you can have 2 TIP's is to have 2 turbo's...
...on the LCR, the Samco jobbie is a straight swap for the original corrugated rubber thing with a split in it... or was that just mine??
CupraR-Rog is offline   Reply With Quote
Old 08-06-2004, 12:33   #9
Yumann
Yumann's Avatar
Does the samco not connect to another metal pipe which then connects to the turbo?
__________________
Leon Cupra R +
Old 08-06-2004, 13:13   #10
CupraR-Rog
Just Cruising...
CupraR-Rog's Avatar
Nope - Samco straight onto the turbo.
Old 08-06-2004, 13:34   #11
Yumann
Yumann's Avatar
Cool cool!
How do the metal tips fit then?
__________________
Leon Cupra R +
Old 08-06-2004, 14:29   #12
RobDon
Senior member
RobDon's Avatar
On the Cupra, you have a metal intake bolted onto the turbo, then a rubber top half going up to the airflow meter. You can get high flow replacement metal intakes but they still use the OE rubber top half. The Samco TIP replaces the lot just like the LCR, from the turbo to the airflow meter in one smooth larger bore hose.
I'm about to replace my Neuspeed TIP/rubber with the one-piece Samco.
Old 08-06-2004, 16:09   #13
Yumann
Yumann's Avatar
I understand now. Cheers RobDon!
Fancy doing a fitment guide?
__________________
Leon Cupra R +
Old 08-06-2004, 16:18   #14
CupraR-Rog
Just Cruising...
CupraR-Rog's Avatar
Remember though, that the R doesn't have the metal pipe
If you get a Samco TIP, it just fits straight on to the turbo on the R.
I would take some pics to show you, but as you can barely get your hand to that part of the engine at the best of times...
Old 08-06-2004, 16:59   #15
Ap_coupe
so are these not avalible for the ibiza cupra?
__________________
Urbanracing www.urbanracing.co.uk enjoy
Ap_coupe is offline   Reply With Quote
Old 08-06-2004, 21:29   #16
colb
colb's Avatar
not at this time which is a shame as a lot of people have shown an interest give samco or forge an e-mail if we all do you never know.
colb is offline   Reply With Quote
Old 08-06-2004, 22:06   #17
Ap_coupe
Good idea. Get ur e-mail sent
__________________
Old 08-06-2004, 22:10   #18
edc
Blue Leather & Shiny Bits
edc's Avatar
Given the Samco hose kit group buy already done you might want to strike while the iron's hot so to speak
__________________
Ed
___________________
edc is offline   Reply With Quote
Old 08-06-2004, 22:13   #19
Shock_Xe
Posts: n/a
whatch this space for a beeza silicone tip,
Old 09-06-2004, 16:34   #20
Ap_coupe
shock xe any idea on a time?
__________________
Reply
Bookmarks
Tags
metal, samco, tip, type
« Previous Thread | Next Thread »
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
(View-All Members who have read this thread : 5
filbro, gazR, Glenn, JMP, wilz
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Website © 2010 SEATCupra.net
Disclaimer: SEATCupra.net is not an official SEAT site and is not affiliated to SEAT in any way. Visit the Official SEAT Website.
SEATCupra.net are not directly responsible for information which maybe posted in this forum.
All content is viewed and used at your own risk. We do not warrant the accuracy or reliability of any of the information.
The views expressed herein are those of the individual contributors and not necessarily those of SEATCupra.net or SEAT
All trademarks and copyrights remain property of their respective owners.
