Revotechnik
Go Back   SEAT Cupra.net - SEAT Forum » SEAT Model Specific Discussion Forum » Leon » Leon Mk1
Leon Mk1 Use this forum for Leon specific topics, for 2000-2005 models only
Reply
Thread Tools Rate Thread Display Modes
Old 12-07-2012, 14:43   #1
phatsam262
Posts: n/a
Problems with Leon cupra r?
I am looking to buy a leon cupra r 225 and just wanted to know the common problems to look out for?
Any advice would be great, cheers
  Edit/Delete Message Reply With Quote
Old 12-07-2012, 14:56   #2
Shmoo
Shmoo has 10 points
hi there. The main common fault that I know of is the doors seal can perish and leak water into the footwells. check that the carpet is not damp and/or that it does not smell damp inside the car. The 02M gearboxes can have worn out bearings even at lower mileage and 2nd gear synchromesh can sometimes be worn out. The gearbox can be expensive to fix if faulty but don't let this put you off. These cars are very good and well built in my opinion. my advice would be give the car a good test drive with the radio off and make sure everything feels nice and tight and it would definitely have to have good service history to prove it's been looked after and a pile off invoices is a bonus. good luck in finding the right one.
Shmoo is offline   Reply With Quote
Old 12-07-2012, 15:24   #3
phatsam262
Posts: n/a
Thanks for a quick reply.
I am having a look at one tonight (2004 with 75k on the clock) and just wanted to check what to look for. He has put on the post it had the door leaks which is the same for any leon but has fixed them. Thanks for pointing out the gear box problem i will have a look at it. I am taking my mechanic so i hope he will pick up on most things. I suppose as long as it has full service history and receipts for all work done then it should be an ok buy. I Hope!!!
Old 12-07-2012, 15:27   #4
traumapat
Leon Cupra IHI
traumapat's Avatar
traumapat has 40 points
Have a read through this...
http://www.seatcupra.net/forums/showthread.php?t=241298
__________________
MY08 LEON CUPRA BTCC
Previously MK1 IHI LEON CUPRA
traumapat is offline   Reply With Quote
Old 12-07-2012, 15:39   #5
Chris4877
Senior Member
Chris4877 has 10 points
On the digital climate control, hold the recirculate button and press the fan up button, this will show 1 then press the recirculate button again, given the owner hasn't deleted them, this should show any fault codes on the car, if there are any write them down and search on here for them
Chris4877 is offline   Reply With Quote
Old 12-07-2012, 15:46   #6
B1rdy
B1rdy's Avatar
B1rdy has 10 points
Quote:
Wow, never knew this. Gonna try mine to see if there's any faulty stored. Cheers
B1rdy is offline   Reply With Quote
Old 12-07-2012, 15:48   #7
Chris4877
Senior Member
Quote:
http://lee69.co.uk/Car%20stuff/Leon/codes.txt
Check the above birdy, goes throgh everything you can check
Old 12-07-2012, 16:06   #8
Muttley
Catch that diesel!
Muttley's Avatar
Muttley has far too many pointsMuttley has far too many pointsMuttley has far too many points
That will show you the faults logged - for the Climatronic system. Nothing else.
Muttley is offline   Reply With Quote
Old 12-07-2012, 16:12   #9
Chris4877
Senior Member
Quote:
Really, I feel so violated ha
Old 12-07-2012, 17:03   #10
phatsam262
Posts: n/a
That checklist for LCR/LC newbies is realy usefull thanks. Aslong as it doesnt have any major faults hopefully i will be driving it home later
Reply
Bookmarks
« Previous Thread | Next Thread »
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
(View-All Members who have read this thread : 60
akchappers, ben_edwards30, Br!dges, brad_barker12, cally77, car.crash, CharlieRCupes, Chefoo, chris205, Chris4877, Conzo_f, cupratdi-matt, Dan1720v, Fozzy84, gb, george_seamons, h0tr0x, ibizacupra, jack_1.8t, James R., Jason-R, jmcuprar, Joel_Lucketti, jonathanp, Keithslippery, klemenmico, kosymodo, kr42yxx, LCRnorwich, lee123, M1C VX, marcus.l, MasserS, matt-drummer, Mick288, mickeyp88, milner575, Muttley, nd-photo.nl, Pommeh, R99AN H, rackers, Richy Cupra, rickyb90, Rickysomerville, Russler, S's Cupra, sambryant, Seal_LCR, Shmoo, t0m, tedvagas, terryliggins, Tigertim001, tombos9, traumapat, virdi, worzel, Xizor, YellowLCR
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Website © 2014 SEATCupra.net
Disclaimer: SEATCupra.net is not an official SEAT site and is not affiliated to SEAT in any way. Visit the Official SEAT Website.
SEATCupra.net are not directly responsible for information which maybe posted in this forum.
All content is viewed and used at your own risk. We do not warrant the accuracy or reliability of any of the information.
The views expressed herein are those of the individual contributors and not necessarily those of SEATCupra.net or SEAT
All trademarks and copyrights remain property of their respective owners.
