| Leon Mk1 Use this forum for Leon specific topics, for 2000-2005 models only> |
Thread Tools | Rate Thread | Display Modes |
#1 |
Newbie
1.8t 20v remap
I know this has prob been asked no end of times, but as a newbie to these cars looking for some quick help.
Il be getting myself a seat cupra 1.8t 180bhp next week and im thinking about getting it remapped. What do i need to get it up to 210bhp? Do i need a certain air filter, fpr etc etc? And how can i check my engine is good for the re-map? And i live in rugby were would be the best place to go? Cheers |
#2 |
Senior Member
It has,look in FAQ's loads there.
#3 |
Newbie
cant find anything lol...
#4 |
Hi and welcome.
If the car is healthy ( not due a service, Starfleet mileage, or generally tired) a stage one map should see around 205-10 bhp. An intake and exhaust won't hurt, but should nt be needed necessarily. Prepare for hoses and coil packs to get stressed though, as all you're doing is winding the wick up. |
#5 |
Fully paid member
Make sure it serviced, buy a jetex cone filter and forge 007p or 008p dv valve. Depending on where you get it mapped they should check and scan the car before they put it on the rollers. AMD did with mine, and got me 217bhp and 261 torque on stage 1 and that was on the hottest day of this year
__________________
![]() Cupra - GONE Cupra R RR - http://www.seatcupra.net/forums/showthread.php?t=367827 |
#6 |
Stage 2 Revo'd
You don't need a new valve if yours is fine.
__________________
My Car Did you not get a manual with your Leon, or want a .pdf copy? If my post has helped you click the scales to the left and leave me some rep points. |
#7 |
have u heard of ****** in leicester they are good tuner , stage 1 will get u about 210bhp , if u add air filter , downpipe , cat back exhaust and DV u will get around 230+bhp !
#8 |
Another vote for Niki over at R-T E C H
#9 |
Newbie
Is a baileys BOV any good? or is it.... Forge or GTFO?
#10 |
Senior Member
Baileys will normally cause the car to go into limp mode stick with either Forge 007/008
__________________
Work in progress |
#11 |
Leon Cupra IHI
Id rate the oem valve in good condition above forge or bailey
__________________
MY01 Ovni Leon Cupra...... lots of shiny mods and a little touch of jabba now running at 320bhp/320 lbs/ft
#12 |
Welcome along mate ....Revo map should see at least 210bhp ... weak components around the engine will give in with the extra stress of the remap etc hoses , coil packs ... good service would do no harm before you get it mapped any way
I've got a stage 1 revo map and a forge 007 and love it makes such a difference
__________________
Cupra Leon REVO'd , forge 007, pipercross filter , cupra r splitter Last edited by 150cupra; 03-01-2013 at 13:29. |
#13 |
When I had mine mapped I had a high flow panel filter and cat back exhaust and tesco 99 fuel but I was advised to fit a forge recirc valve with a yellow spring but a few thousand miles after map my coil packs went so replaced all 4 (leon fr180) 207hp 262lb ft torque I don't think the exhaust makes much difference without down pipe and decat though
#14 |
Do you need uprated coil packs with a stage 1? Or Isit not worth it? How much psi can the standard DV handle? Would you see a difference with a stage 1 changing the standard to a 007?
#15 |
Senior Member
Don't need uprated coilpacks mate standard are fine. I fitted 4 new ones from Audi when 2 went of mine went. For what it costs for a 007 I would get one fitted mate.
__________________
Work in progress |
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | Rate This Thread |
