CHIPEX
Go Back   SEAT Cupra.net - SEAT Forum » SEAT Model Specific Discussion Forum includes Members Projects » Ibiza » Ibiza Mk4
Ibiza Mk4 For the 2002 - 2008 model
Reply
Thread Tools Rate Thread Display Modes
Old 18-06-2004, 15:58   #1
magga
magga has 10 points
help with ibiza mk4 front door card removal
could anybody give me some instructions/pointers in removing the front door card in a mk 4 ibiza. I have a rattle coming from the front left speaker. Needs investigating. cheers
magga is offline   Reply With Quote
Old 18-06-2004, 19:31   #2
Tom B
Senior Member
Tom B's Avatar
Tom B has 10 points
Theres a guide I made that's floating about...I haven't got it anymore.
__________________
Tom - A3 2.0 TFSI Quattro S Line
Previously...Ibiza Cupra TDI, 2x Ibiza TDI Sports, Ibiza GTI 2.0 16v and Cordoba SX 2.0 16v
Tom B is offline   Reply With Quote
Old 19-06-2004, 10:59   #3
muddyboots
Still hanging around
muddyboots's Avatar
muddyboots has 20 points
Try PM-ing Big Ali H, he sent me a copy a while back.
Don't know if it's the same guide as Tom is talking about (it did mention the name of - shh - another rival site, if that helps...)
__________________
muddyboots is offline   Reply With Quote
Old 19-06-2004, 12:39   #4
Tom B
Senior Member
Tom B's Avatar
Tom B has 10 points
Someone send me it again, and I'll edit it to add more stuff. It was very rough and hasn't cover a few other points.
I've lost it twice now!
__________________
Old 20-06-2004, 16:02   #5
magga
magga has 10 points
Cheers. I have done a few searches but dont seem to be able to find much. I could probably work it out but dont want to go breaking some clips in the process.
Old 20-06-2004, 17:11   #6
Tom B
Senior Member
Tom B's Avatar
Tom B has 10 points
It is quite simple, but with a trim tool its a lot easier.
You need to undo 2x T15/T20 (can't remember which) bolts from the bottom, then undo the two cross head screws inside the grab handle and then gently pop the clips around the edges. It gets tricky at the top where it joins the window, some wiggling will get this free. Undo the wires from the switches carefully (my electric window one broke when I was undoing it on this car) and then the card wil be free.
__________________
Old 03-07-2004, 21:35   #7
Ballie
Ballie's Avatar
Ballie has 10 points
I can send you the old copy i have but if i remember you said it was no complete. Email me if you want me to send it too you anyway.
Geoff Ball.
__________________
2005 Mk1 Leon TDI 130
Ballie is offline   Reply With Quote
Old 03-07-2004, 23:36   #8
DaveP
Small Member
DaveP has 10 points
Worth remembering to pull the door card away enough to clear the top attachment points, otherwise you might break them (like me).
__________________
Extreme Blue Ibiza tdi 130 sport
DaveP is offline   Reply With Quote
Old 05-07-2004, 07:26   #9
big ALI H
Cavey
big ALI H's Avatar
big ALI H has 10 points
Heres the guide minus pics as i can't upload the attachment at the moment for some reason!
How to remove a 2002- Ibiza door card
DISCLAIMER: Myself nor the SEATCupra.net group can be held responsible for any damage caused by following the below guide. Everything performed is at your own risk.
1) First of all you will need to remove everything from the storage compartment in the door card, so that when you take the card off it doesn’t all fly everywhere.
2) The next step is to remove two screws from the bottom of the door card (see picture below. These need a Torx T15 screwdriver to remove. You can pick these up from Halfords or your local DIY store.
3) The next thing is to get a flat headed screwdriver and take off the cover on the interior door grab handle. Once that has been removed, undo the two large screws that are inside.
4) Some judicious manipulation may be needed for this one. Start at the bottom and working your way upwards pop the clips around the card. Be gentle with these as they can break…I broke one on mine when doing it a bit hard, luckily I plastic welded it back together. Now you need to basically get the bottom of the card and hit it upwards. This will release the top of the card. Be gentle and wobble it free. You have wires coming from the card so be careful to undo these.
That’s what it will look like once the door card is off. The metal cover behind the door card is very difficult to remove and is attached to the electric window motor system, I suggest you attempt to remove this only if you are really desperate to. Again, we at SEATCupra.net or myself can be held responsible if any damage is caused.
To take off the pod where the tweeter is located:
1) Open the window fully.
2) Use your hand and grab the pod. Twist this towards you and the clips should unpop.
For everything, refitting is the reversal of removing.
__________________
AL
Now in an Audi A3 1.9 TDI. Previously Mk4 Ibiza TDI Sport, Leon Cupra 20VT amongst a whole heap of others!
big ALI H is offline   Reply With Quote
Reply
Bookmarks
« Previous Thread | Next Thread »
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
(View-All Members who have read this thread : 71
Ads-ibiza, ant5735, benuk, blackdiamond200, boraman, bundy1981, CGD217, Chieftec, chrisa10, chucky, creatz, damiwahn, darkhorse, Darzy18, dasmith83, Dave_b, davidpugh, DCLARK08, Dopsonj, Eboneezer, excess, falling_feeling, fil_b, fr930, Gaz13, george130, harddiillion, islander222, JakeGwilliam, jamie18, JamieC19, Joe's MK4, JoeCav, John99041, Jonas70, jtonline, K.I.T.T., Keith_Ibiza, kopec56, LazyBrit, lex26, mark.w, Marler, matteggleton, mc_burton, MNW, moggytom, morley107, NissimFR, Pete.Milsom, PSV6, QuietQuackers, Rob26, scotbren, shox, snk, strykezero, sydoggkdy, TALBOTL, teeth2k, TienShan, Toby-Veart, Trimmy, twoscoops, typezero, T_higgs89, Vasily87, Veyron, wealthysoup, wezzo11, Wooller
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Website © 2013 SEATCupra.net
Disclaimer: SEATCupra.net is not an official SEAT site and is not affiliated to SEAT in any way. Visit the Official SEAT Website.
SEATCupra.net are not directly responsible for information which maybe posted in this forum.
All content is viewed and used at your own risk. We do not warrant the accuracy or reliability of any of the information.
The views expressed herein are those of the individual contributors and not necessarily those of SEATCupra.net or SEAT
All trademarks and copyrights remain property of their respective owners.
