Chris Knott
Go Back   SEAT Cupra.net - SEAT Forum » Announcements, FAQs & Rules » ** FORUM RULES & FAQ - Please Read **
** FORUM RULES & FAQ - Please Read ** Please take some time to read and understand the rules of the forum. Ignoring these rules doesn't absolve you from the consequences of not following them.
Reply
Thread Tools Rate Thread Display Modes
Old 29-08-2015, 01:17   #1
Scarlet_Witch
Newbie
Scarlet_Witch has 10 points
New here but help required mk4 ibiza misfiring
Hey so back in may I posted a thread about my car misfiring from cylinder 1.
I still have the same issue but the cars been seen by the garage I bought it from so far he's changed the coil in cylinder 1, didn't work. Changed the spark plugs, didn't work. So he had it in the garage for 5 days in may and said he fixed the fault it was a wiring issue in the loom 2broken wires apparently. Well it's ran fine since but guess what it's misfiring again from cylinder 1. So now I'm turning to you guys for help. The car runs fine but when sat idle at traffic lights etc it starts with a little shake then turns into a misfire. I have to turn the engine off then on to get on my way
Iv also noticed that if I sit in traffic with some revs on it doesn't misfire
misfire. Seems to also misfiring easier when on a hill facing upwards or downwards..I apologise if my thread is in the wrong place iv only posted once before so I'm kinda new. And this is my first car so please speak to me in simple terms as I don't have a clue but trust me I'm learning the hard way. Thank you all
Scarlet_Witch is offline   Reply With Quote
Old 29-08-2015, 01:40   #2
Fmxvxx
Fmxvxx's Avatar
Fmxvxx has 10 points
It sounds like the vehicle is under fuelling at idle I would look at the injector for cylinder 1.
Fmxvxx is offline   Reply With Quote
Old 29-08-2015, 01:46   #3
Scarlet_Witch
Newbie
Thanks it's worth a go I guess never been suggested. Thanks. Is there a way to test this without buying new parts? Iv spent so much money trying to fix this I don't want to buy parts and it not be the issue.
Old 29-08-2015, 01:58   #4
Fmxvxx
Fmxvxx's Avatar
you can read the injector flow rates with a decent scan tool you can also rule out the wiring by use of a noid light plugged into the injector wiring, removing the injector and inspecting would also be advised.
Old 29-08-2015, 02:10   #5
Scarlet_Witch
Newbie
Thanks. I'll see if I can get one of the guys to have a look at it. As i said my first car so still learning. Would injector issue make the car run sluggish or cause misfires on other cylinders or are injectors linked to cylinders. My car only has 3 cylinders so it's awful when only 2 work like a tractor.
Old 29-08-2015, 02:32   #6
Fmxvxx
Fmxvxx's Avatar
if the injector flow was poor or the spray pattern was not correct yes it could cause sluggish performance or misfires as the cylinder is not getting enough fuel for proper combustion.
and to be fair it sounds awful when running on 3 cylinders as well
Old 29-08-2015, 02:39   #7
Scarlet_Witch
Newbie
Haha hell yea running on 3 cylinders isn't good but it's a cheap car so hey. My exhaust sounds awful like there's a hole but nothing there. My friend has a 3 cylinders skoda fabia 1.2 and hers sounds fine unlike mine. Garage told me it's sounds raspy cos it's 3 cylinders but I think it has another issue.
Old 29-08-2015, 03:09   #8
Fmxvxx
Fmxvxx's Avatar
a lot of 3 cylinders suffer from "Rough" running having to use a balance shaft to keep the engine from knocking all over the place was never the best idea but economy is king at the moment.
If you're in Watford or the surrounding area I'm happy to take a look at it for you.
Old 29-08-2015, 11:57   #9
Scarlet_Witch
Newbie
Awww thanks very much but I'm up north in Cumbria. Ah well I'll cope with it sounding like a wasp in a tin for now haha. Can't wait to have the finance paid off. Bought the car cos I though it would be perfect only having 30k miles and it's 7 year old
Reply
Bookmarks
« Previous Thread | Next Thread »
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
(View-All Members who have read this thread : 4
Fmxvxx, hilly81, kazand, Scarlet_Witch
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Website © 2014 SEATCupra.net
Disclaimer: SEATCupra.net is not an official SEAT site and is not affiliated to SEAT in any way. Visit the Official SEAT Website.
SEATCupra.net are not directly responsible for information which maybe posted in this forum.
All content is viewed and used at your own risk. We do not warrant the accuracy or reliability of any of the information.
The views expressed herein are those of the individual contributors and not necessarily those of SEATCupra.net or SEAT
All trademarks and copyrights remain property of their respective owners.
