| Ibiza Use this forum for Ibiza specific topics |
Thread Tools | Rate Thread | Display Modes |
#1 |
Posts: n/a
HELP! abs light is on
need some advice please ,had to brake hard today as i met a lorry on a bend, the abs light came on and hasn't gone off.
i took the car for a few runs up and down the by-pass and when i broke HARD i could lock up the back wheels the fronts are fine and can feel the abs working on them ,i presume that there is two separate systems,or circuits to them,any way is there anything i can do myself to sort it or is it a trip to seat and a plug in the 1551? can the system reset itself or does it have to be a main dealer(was thinking of dissconnecting battery and seeing if that'll help,probably not)any info or help at all please. as i'd like to buy new wheels this week end not give it to seat.thanks as usual AND NO WISE CRACKS BRENDY
#2 |
FOOORRREEE!
as far as i knew yes mate, though it may be expensive as its out of warranty!
__________________
Estoril Blue BMW X5 4.6IS Shiney Flash Red 2004 Leon Cupra Now Gone .World Rally Blue Bugeye WRX, silicon and shiney bits under the bonnet. |
#3 |
Available In Race Blue
Sounds like.
The time my mate broke so bloody hard he managed to keep both the ABS light and both his rear brake lights on cos he forced the brake pedal into somewhere it shouldn't have gone...try fiddling with the pedal itself (.i.e waggle it about, see if it's gone to far - there is a microswitch down there) Also check your rear brakes lights are not permanently on...although this is something i'm sure you would have noticed!!...other than that it might be an ABS wheel sensor (only one has to go for the system to display an error).
#4 |
Posts: n/a
will try all them ,anything to avoid paying seat for the pleasure
#5 |
If you could...
Get to Amythyst on a not so busy time, I'm sure they would at least chuck the diagnostic kit on for 5 mins. That at least would say if it was a wheel sensor.
#6 |
Cruising with the 6 Pot..
Location: Easy life Cruise control with 200bhp of Bavarian RWD slushboxed Leather Comfort :)
it should register what has happened , and a reset and test will double check
may JUST be a sensor range outta line, BUT needs checking ABS/AIRBAG circuits are VERY sensitive and scream "FAULT" JUST to be double safe
#7 |
Posts: n/a
cheers all ,spoke to graham today daz ,you boys and girls are busy till next week ,the new one at driotwich failed to call me back
![]() but graham assured me that their is no danger ![]()
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
(View-All)
Members who have read this thread : 0
| There are no names to display. |
| Thread Tools | |
| Display Modes | Rate This Thread |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Toledo Sxe 1,6lt 1996 Abs Warning Light | xenophon74 | Problem Issues Q&A | 12 | 04-12-2004 15:42 |
| abs light on all the time | mark-wrx | Problem Issues Q&A | 2 | 09-07-2004 16:28 |
| ABS light coming on whilst on motorway. | DanielTheManual | Ibiza | 3 | 26-01-2003 23:49 |
| ABS light | Sanjay | Leon Mk1 | 2 | 17-06-2002 19:48 |
| ABS Warning Light | SJFISHER67 | Leon Mk1 | 1 | 29-05-2002 16:19 |
