Hello everyone !
After reading a lot of things about the Seat ibiza cupra on this forum (including Lucifer's excellent guide), I decided to post here because I think (I hope!) that you may help me.
My seat ibiza cupra 1.4 TSI from 2010 is now 127k Km, and has the engine emission light ON since I bought the car (105k km). The car has no mods.
The code I could read with my ELM327 was : P2188 "running too rich at idle"
This code used to appear only when I parked the car after a trip (short or long, no matter)
This is what I got replaced during the first year (march 2015 to now)
- intake air filter
- coils & plugs
- low pressure fuel pump
- injectors
Last time I got to the dealer, they told me they found a new amazing additive (G 001780 M3) to "clean the high pressure fuel pump", but I found on the net it's a multi purpose additive used to clean the carbon build up. So now I'm kinda bored of constantly giving my car to the dealer for nothing...
Now those are the symptoms I had :
-detonations in the exhaust at low rpm when I'm slowing down : for example, i'm at 3 000RPM on 2nd gear, I let the car slow down on her own (not braking) and when the RPM goes at ~2 000 RPM I can hear a serie of "poc poc poc" in the exhaust
- difficult start when cold : a few seconds before the engine start. When warm, it starts in under a second
Those symptoms are "hard" to catch up and I've been running one year with those, while replacing the parts one by one
The problem is, last week, I made a lot of consecutives short trips (5-10mins) : the more I started the car, the more it seemed to be difficult for it to start. On my last trip, while I had the key turned in, the rev were not higher than 300 for several seconds, and when it started they went slowly up to the idle revs (~800)
Usually when I start the car, the revs go up to ~1500 and then go down to idle, so something was definitely wrong.
After this event, I checked the exhaust and saw black smoke coming out (just a bit, I could only see smoke like ~20cm away from the exhaust, not more). My ELM327 also took another fault : P2178 "running too rich OFF idle".
Even more, the car now make a loud noise when starting cold (not like the timing chain rattle you can find on youtube, it's more low-pitched)
Lastly, I calculated at my last trip a consumption of 10L/100km (instead of 8)
I will bring the car wednesday 29/06 to the dealer again. They want to check the cylinders compression
I can't manage to find similar stories and I'm afraid about the piston weakness, or the timing chain failing....
Anyone would be able to give me indications on what I should focus on ? Could be just a leak in the intake manifold ? Or maybe something far worse ? I'm just lost
I thank you in advance for your help,
Thibault
- intake air filter
- coils & plugs
- injectors
Thibault
