My Mk3 Ibiza Cupra I bought less than a year ago. It was a local Bristol car originally purchased from Bristol SEAT, with only 48K thousand miles, all history. It's had a blueflame cat-back, Jetex filter, front mount intercooler, turbo intake pipe, forge relocation kit, forge 008p and a custom code Stage 1. I was looking for a very clean base to build so wasted no time, drove it for a week, parked it and got to work.
Current Specification
Engine
AYP 1.8 20V Turbo rebuilt at 48K miles
THS Forged Conrods
BP Wideband conversion using pro made harness by Benjamin Parsons (Easily switch between wide and narrowband ECU's)
LCR BAM K04-023 stock turbocharger
LCR BAM 225 ECU
LCR BAM 225 3” MAF
LCR Wideband 02 sensor
Stock BAM K04 TIP
Stock 3 Bar FPR
Stock 1.8T Coilpacks
NGK Laser Platinum spark plugs
LCR 3 inch MAF
Relentless Pro4 exhaust manifold
QPeng 2.5” K04 downpipe
Blueflame 2.5” cat-back exhaust with oval tip
Ramair open cone filter
Toyosports Type B 600x300x76mm FMIC
Toyosports 2.5” cooler pipework customised to perfection
Custom radiator brackets to move rad back for a flush cooler & bumper fit.
Custom oil return line
LCR Charge pipe with custom brackets to retain OE look
LCR Various hoses and pipes for OE look
Forge 008 Recirculating Valve
AC Delete, Non-AC Aux belt fitted
N249 Delete
N112 Delete
SAI Delete
Carbon Canister Delete
Evap Delete
EGR Delete
Creation Motorsports blanking plate
Venting straight to atmosphere
Transmission
Stock 5 speed box
ECS G60 Flywheel from Awesome GTI
ECS VR6 Clutch from Awesome GTI
Chassis
Weitec Coilovers
Seat Sport Strut Brace
Stock brakes
Stock brake pads
Stock discs
Interior
Full stock interior
Ibiza Cupra R twin gauge pod
Boost gauge
Oil pressure gauge
Exterior
Rear wiper delete
Pictures courtesy of the previous owner who I believe may still be on the forum. It's already got a SCN sticker so that saves me a few pennies.
Engine
THS Forged Conrods
LCR BAM 225 ECU
LCR BAM 225 3” MAF
Stock BAM K04 TIP
Stock 3 Bar FPR
LCR 3 inch MAF
N249 Delete
N112 Delete
SAI Delete
Evap Delete
EGR Delete
Transmission
Stock 5 speed box
Chassis
Weitec Coilovers
Stock brakes
Stock brake pads
Stock discs
Interior
Full stock interior
Boost gauge
Oil pressure gauge
Exterior
Rear wiper delete
