OBDeleven modifications
Igor0511
Thanks.
For sport menu I meant on a tab in Car view.
I cannot post links yet (before 15 posts), so I'll copy an URL with a space before .com
youtube. com/watch?v=D-THD8QMxgQ
Igor0511
Car is manufactured in the end of 2016.
Edit: I just checked in manual. It says that all devices with 6.5" media system are MIB2?
So then I should have this feature.
D3RV15H
24
Welling
Hi. Has anyone had any issues with coming home / leaving lights? I've noticed recently that mine are not working as they should and I'm not sure why? I've not made any changes using OBDeleven for quite a while so unsure why this has happened all of a sudden?
Was wondering if someone might know if there are 'default' settings for the coming home / leaving lights function and if so how I'd go about changing these via OBDeleven?
Any help would be appreciated.
superdon
99
9
Sorry if this has already been covered, but does this work ok with the new 2017 model?
paddy6789
1,627
1,079
Preston, Lancs
Has anyone managed to find a way to have the windows auto close when locking, without holding lock button on the key until the window(s) are fully closed?
Seat Leon Cupra 290 DSG Black Edition
Racingline R600 intake
devJORD
OBD11 Wizard
Nov 14, 2014
387
I have the facelift. Some stuff works as usual. There are a few things that dont work, like changing the comfort indicator length, sweeping dials and I swear the facelift 1.4 has a sound actuator because my pre-facelift 1.4 didnt sound like this at all.
Sent from my SM-G955F using Tapatalk
R4CK5
609
85
I have the sweeping dials on mine but was activated with vcds not obdeleven. Not sure how the 2 systems compare?
devJORD
OBD11 Wizard
Nov 14, 2014
387
I'll have a look at the long coding and try that.
Thanks for the clue.
Kilipri
Hi,
I'm new to the forum. I've searched the forum and I saw no info related to what I'm about to ask. I've got interested with some info in this thread and took some notes down. Thanks for that.
I'm trying to understand an ECU fault code OBD11 gives me. I'm unable to find any info on the Internet after a few hours. Hopefully this could help, if solved, to someone not to spend the whole afternoon in front of the computer..:).
Getting to the point, the error I receive when scanning is
B202300 - Partial functioning due to active protective function
Priority 6, happened once and is marked as sporadic. I guess it's safe to delete, but feel curious what it can be (I think I was parking when it occurred, factoring in the timestamp it gives).
I know there are fault codes lists. But this code is not included in any of them.
Thanks for any help.
AndrewJB
Aug 16, 2007
11,211
484
Maranello
My OBD Eleven dongle has stopped working. only had it 5 months.
Going round and round in circles with the support email, asking me to try different phones and even different cars even though I have already done that. comes with 1 year warranty or maybe even 2 be interesting to see if they actually send me another device.
KoNG
466
98
Canning Town
Ill share with you coding for old ABS unit (2013-2014) which doesn't have byte 29 to do coding for ESC Sport/OFF. This unit usually has finished with byte 28 value C0 s TPMS or value 40 without TPMS.
If you want ESC sport/OFF on this unit change coding in byte 25 mark bit 4
After this you will get this setting menu
Smithcd
49
Do all spec Leon's mirrors have The folding motors in? I have a MY16 se tech. I don't want to alter through long coding only to find out it would never have worked and unable to revert the coding.
kiddo
ST Cupra
May 30, 2015
1,151
99
Lancashire
Re: footwells
I thought they went off anyway in when no headlights on? My footwells (led) come on with interior lights when door opens but they do go off if no lights on.
