Opie Oils
Go Back   SEAT Cupra.net - SEAT Forum » Diagnostics, Tuning and Modification » VAG-COM & Diagnostics
VAG-COM & Diagnostics VAG-COM is a diagnostics program that allows your PC to talk to your ECU - All VAG-COM / 1551 questions to be posted here
Reply
Thread Tools Rate Thread Display Modes
Old 27-01-2005, 17:19   #1
davidhunter
davidhunter has 10 points
modules measuring blocks and adaptations
Hello all,
I have just spend hours auto scanning through all the modules on my 1.8T Cupra 2003. I have gone through all the measuring blocks and adaptations and have put them into a word document. Question is how do I attach a word document to this message? I cut and paste and it looks rubbish as it looses the formatting.
Also once/ if you see it give me a hand and tell me what I can do with all this data cheers.
David
davidhunter is offline   Reply With Quote
Old 27-01-2005, 18:20   #2
davidhunter
Think this might work it did on another site anyway. If you think there are mistakes you can change them and if you understand what half of them are then share and share alike.
Davy
Old 27-01-2005, 18:31   #3
m0rk
sarcasm comes free
m0rk's Avatar
m0rk has 100 pointsm0rk has 100 points
wow - that's some good work there!
__________________
m0rk is offline   Reply With Quote
Old 27-01-2005, 19:23   #4
davidhunter
Cheers mOrk,
I had been looking for a list like this for a while and could not find one so thought I would do it myself. I think there are a few mistakes purely down to my own hand writing and some of the abbreviations I am not sure what they mean. I know things like post and pre C are relating to the catalitic converter. Dont know what bin bits is about and there are a lot that say no units. I also wonder how many more there are when the engine is running or are these the only groups used either stage two ignition on or engine fully running? who knows !!
davy
Old 27-01-2005, 19:39   #5
Cupra R
Senior Member
Cupra R's Avatar
Cupra R has 10 points
Interesting read this mate, thanks...
Cupra R is offline   Reply With Quote
Old 28-01-2005, 01:44   #6
Uwe@Ross-Tech
Uwe@Ross-Tech's Avatar
Uwe@Ross-Tech has 10 points
http://www.ross-tech.com/vag-com/labels.html
-Uwe-
Uwe@Ross-Tech is offline   Reply With Quote
Old 28-01-2005, 11:08   #7
Simon L
225 TTC Quattro
Simon L's Avatar
Simon L has 10 points
Nice work mate, thats very usefull.
__________________
New car: Audi 225 TTC Quattro with Revo | 0-60: 5.75 | 0-100: 14.0
Old car: Ibiza 20VT with StarPerformance | 0-60: ?.?? | 0-100: 14.6
Simon L is offline   Reply With Quote
Old 28-01-2005, 14:31   #8
davidhunter
Cheers Uwe,
Now as I get better using VAG COM I think I will try and make one of these files for the AUQ 1.8T engine I have a lot to learn first though. I think it would help out a lot of people. Is there likely to be more results showing up in the 4 displays when the engine is running ? or is it OK just to make/ alter a label file from the information when the cars electrics are on but the engine is not started?
David
Old 29-01-2005, 15:30   #9
basstard
Dropping Cogs is Useless
basstard's Avatar
basstard has 10 points
I remember uwe posting a similar doc [from tdiclub] with all the TDI engine blocks, does anybody have/knows all the others?
__________________
2007 LS7Y Leon Sport TDI 140|GT1749VB|Custom Remap|Full Red Leather Retrim|18" BBS Speedline RS866|Audi TT Short-Shifter|OEM Xenons|Cupra Front Bumper
basstard is offline   Reply With Quote
Old 30-01-2005, 00:42   #10
Uwe@Ross-Tech
David,
You can do 90%+ of the work with the electrics on but engine not running. The only problem with the engine not running is that the data is pretty static. At some point before you publish, make a "reality check" pass through it with the engine running.
You may also find this link useful:
http://www.ross-tech.com/vag-com/m_blocks/index.html
Basstard,
http://forums.tdiclub.com/showflat.p...&Number=258487
-Uwe-
Old 30-01-2005, 10:59   #11
davidhunter
Great help Uwe thanks may rip off your measuring blocks set up looks good like that
Davy
Old 30-01-2005, 19:03   #12
davidhunter
found another interesting site for teh DTC's
http://1.8t.org/~quattroman/Audi%20B...de%20table.pdf
Old 31-01-2005, 16:16   #13
basstard
basstard's Avatar
Quote:
Originally Posted by Uwe@Ross-Tech
Yep, I knew that, I remember you posting that a while back ago [see my previous post] but I was asking if someone knew about all measuring blocks for ALL the blocks on a tdi [i.e. not only engine].
I'm concerned about doing a test on mine because I fear for the battery life.
__________________
Old 31-01-2005, 16:28   #14
Uwe@Ross-Tech
Ah, a "TDI" is a type of motor, not a type of car...:-)
I'm not aware of any lists specific to the other systems in an Ibiza.
If you're worried about battery life while "playing", either connect up a battery charger to the mains, or let the engine idle while you play.
-Uwe-
Old 01-02-2005, 13:18   #15
basstard
basstard's Avatar
-Uwe-
Yes, sorry, I was wrong
I thought we were talking about the ibiza [but re-reading 1st post says cupra 2003 so it must be a leon]
__________________
Old 01-02-2005, 19:01   #16
davidhunter
Sorry basstard,
Should have said a Leon Cupra !!
Old 05-02-2005, 16:57   #17
basstard
basstard's Avatar
__________________
Old 18-08-2005, 12:53   #18
tji100
Newbie
tji100 has 10 points
46 - Central Convenience
Anyone have any idea why I cannot connect to control 46 - Cent. Conv. using VAG-COM 311.2 and a serial cable on an 05 Leon FR? I have run a scan and I seem to be able to connect to all the other available controls according to the sticky in this thread but not this one, which is extremely useful!
tji100 is offline   Reply With Quote
Old 18-08-2005, 13:25   #19
basstard
basstard's Avatar
On the same lines, I can't connect to module 35: central locks. The mk3 should have one [it tests it in the auto scan]. It doesn't give any error message,,, it just seems like there ain't a module 35.
Anybosy has a clue?
__________________
Old 18-08-2005, 13:40   #20
goble
Senior Member
goble's Avatar
goble has 10 points
yer its through 46 comfort & convenience control unit
only arosa has 35
goble is offline   Reply With Quote
Reply
Bookmarks
« Previous Thread | Next Thread »
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
(View-All Members who have read this thread : 758
-=Rob=-, 0000zoon0000, 20 valve ted, 303jon, 50spence, 528ben, 747_727, 8bit, 90dv, A-spot, A.m.C_Ibiza1, a.m.s, a123b, AaronGS, Adam4D, adaml, AdamRoutley, adm013, adzer, air121005, ajb, AlanUK, Aldvrn, alexbradford, alex_cupra09, alfredobotswana, Alhambraguy, Alhambratdi110, allbutt55, allh2k, alpha955, alpick36, alx_chung, amstel, Andrewcupra TDI, andrewfx1, AndrewJB, Andy McCombe, andycupra, ANDYH1966, andyj, andypandypoos, andypotts1981, andyspencer, antony-lcr, antp, AP2000, Ape, AP_V5, Artmasterx, Ash.LCR, audiintegra, auq, aussie, AUTO EMOTION, Avant4me, AVIHAI-TOPOR, aymen_a22, Azza_, A|exandre, b21playa, badat_81, badbill_uk, Badger89, BAGZ, Bakes100, BALTAZAR2003, Banana Man, bane_punk, barachello, barry4ord, basssound, basstard, Bazzle, bbewekim, bblqg99, Bbrooks, bdavid, bdengineering, BeartheBruce, belfastchris45, ben652, benhampshire, Berg, Bertee, bertrum, besty, big rich, Bignod00, Bigpul, Big_daddy, Big_Lad, BIG_Y, billyhas, Binksy, Black TDI Turbo, black04ctdi, Blobster, bloody_typical, bodi739, Boisee, Bondiblu, bonsaiman, BoomhaueR, BoostHard, bowk69, brad1002, brad_barker12, bramble, brasso88, brightmix, Browntown, burnsy_b, buzbi, byerss, calum001, Calum_Cupra, Cammage, camon, carlossus, catthowe, CD, cfcmick, chapelhill, charnandy, Chino_UK, chris1788, chris1985, chrisdoxy, ChrisGTL, chriskarl22, chrisr45, Christoph, chris_cc, chryslerben, Cisku, cjhawker, Claki, clarkey2r, Cleg85, cleverspoon, co004, Co2, cookie 6458, cooper61uk, coops10, cordoba lad, corradophil, cossydave, Couga85, Cowie, CrabPaste, Crack-D, Crafoo, craig lcr, craigd, Craigus, cube5, Cupra R, Cupra Ross, cupra-8v, cupra-db, cupra-gaz, cupra-tfsi, cupra.al, cupradan, Cupraken, CUPRAMUNKY, cuprar54, cuprar99, CupraR_Lad, CupraSean, cuprawill, Cupra_20vT, Cupra_Mat, cupra_r_ick, curryholic, curtis3431, D-MInd, Dai_O, Damoegan, Dan1720v, DandB, dandebiz, Dandle, danfr, dann, DannyC87, DaNnY_LaD, DARREN2, DarrenG, davea4, davemgill, davescupratdi, daveyboy32, dave_6, davidcupra, Davidsr, Davidt1033, dawa0000, daz1970, Daza, dazjstuart, DEAN0, Dearnie, deftones, deltron, densil, dent, depex, dErZ, dg-1984, dholdi, dicky FR, diddles, didevldo, Dieselman 73, diggerbycroft, Dilligaf, dirk1978, Disco_Mikey, dod500, dodsmeist, DOLBY, Dolly_Gti, DomH, domin8or, dom_f, dongrofo, Dox1966, drance, dreamonn, DSUK, duke3d2d, dukemaster17, dwebber, Eagle21, ebeem, edmong, edpeckham, eggy524, EL, ElasticTangent, Elliot29, epox, evvo, Exe_LeonCR, EZ Tutty, F2 Ed, Fahid82, fergusmk2, ferooo, Ferryman, fever, ffotografo, fishman, flappy, Forbez, fourtwofive, freamy, frogger, FRozz, fyfe9, g11-snr, G223, G2232, G4R3TH, gajdar, gammar, garethgje, gavbey, gav_1, Gav_F, Gaz5350, gazR, gaztaman, gazza995, gcott, gdjohny, geoffjuggs, George 3G, George657, georgebibizafr, GeorgeChios, germander, gex18, gezmeister, gillygilbert, gingerben, gio, gk002, GlanzaV, Gods, godzuki, golfgtikiw, GolfRS, goodridge, gooh, Gooner_Mike, GotBoost, grale22, greck999, green87, greesha, gregorcupra, GREY 225, grq, guiddruid, Hamzilla, Hargo, harmakhis, Harris., harty190486, Havok316, hawtin1584, HEADGASKET, Healyrae, Herr.Barbi, Heysham, Hobbiniho, hpoolsteve, hulf_fr, hyphon12, i3ai2t, ianhb, ibizaCR, ibizacupra, iCupra, ijmok, Imteyaz, ipd56, J0N, j976rna, jacko_86, jack_1.8t, jaf2212, jake, jakex, jamandspoon81, james walker, james.l, james.milroy, JamesL, jamesypyk, Jamie B, jamiebennett81, jasc1988, Jayt, Jayzx, JB!, jcc-gttdi150, JDCupraR, jds, JDUB 20V, jef, jeggy, jgy6000, Jimmeh, Jimski, jj06, jmh0804, JMP, jnbeck, joedalton, John Cowan, johnboy98, johnbuz, jonathangosbee, jonathanp, jonathan_phang, jonesy118, jonjay, Jonny95 SXE, jonnyblease, JonTelfer, joop200789, Jordan20vt, Jordanwaterhous, joshbro90, JP6, jrs stan, JULE5, JUS CRU-ZN, jwhat, K.I.T.T., karaman, kareemsafwat, KarlB1, Karlosthemarra, kart19, kartdemon, kbrad44, keany19, kegger, Keithslippery, kenno69, KernowFR, Kevgrady, kevh, KEVINTHEGERBILE, kewe, kinder, Klone, knackerdecobre, koush, ko_racer, Kris@Forge, kriso, kurtbil, kylepiggy, kyte66, L.R.C., L14M_T, L30N DG, Lagosta, lamchops, landie9, laurieh1987, lauton, Law121, LCRglen, LEE69, LeeC, leeroy1988, leeuk123, LEO-RS, leon cupra r, LEON4, LeonFR07DSG, LeonFR150_r, LeonQH, lesinge2k, Lewis225, Lewvr6, liam890, LiamUK04, libiza2007, LJA, Lodey23, LongJohnIbiza, Lucio Bravo, ludders, Ludwik Monteiro, Lui, LukeK, mad-for-tar, MadsenTDi, magicmcfc, Mak_unioms, Mancseat, manks88, marcdonnelly, mark garfoot, Mark300zx, markm, mark_eisner, martin150, Martuff, Martyn, mason88, Matt-V5-Duffy, MattBennett, MattBry, mattdavies, mattgcupra, mattw551, matty85, matylad, mcculloch, Mckenzg, mcsolle, mds1256, mec82, Meltdown, mentalmechanic, mhoult, mif, Mike225, Mike90, mikemk4gti, Mikey P, mill5y, millzeee, milner575, minimexa, mitsonen, MJ, mjhmjh2, mk1tt16v, mk2leonfr, mk2_paul, Mo Arif, moali360, Modelmakerman, Molehill_Mike, MooRzy, Mr Bigglesworth, Mr OCD, Mr Roboto, mr.Linatsa69, mri, MrNailer, MrNorma, mrvavavoom, mrwookie, Mr_Magistus, mt audio, Murdered LCR, mush, Mute, Muttley, Muzza1742, MWG, n11tht, N2KHL, nac34, Nam-uk, ne11er, nedjo, NeilMcK, Neil_Ireland, NeMeSiS999, NI3K, nick9one1, nightflight, ninjabadger, Nkon, noblem, NoFriegue, notmoby, NottsLCR, NSOUSA, obou, OFI, oldman, Omagh.NI, Ovni_cupraR, p34ch3y, panoszoe, Paul B2010, paul6316, PaulyboyUK, pekingprawn, Pesders, peterdav, pete_266, petrolheadjim, phantombantam, Phat Busted, phatchoonz1, phi1, philje123, Phillc, PhilW, Phil_JJ, phunkymonkey, plattsy, popem, POPOV, posterboy, praktorakos, Prebs, predii, printech16, processpaul, pukka69er, Pyro, r2d2hp, racingsquirrel, ragz, rallynut, Rapido, RaptorZX, RDS, reflexuk, RichardA, richardc, richard_skinner, Richy!!!, rickyb90, ridge-racer, rikwandi, Rlawrie45, Robbie C, robdf2, RobDon, Robertjwebb, robthebubble, Rocky Rocastle, RodneyA, Ronin225, ross p, Ross_Cupra-R, rs155, rs2-f1, RS6, rsmith, RSTuning, RSYOD, RubenD, rudgey, rudolf2, rvdbarnes, ryanc75, S's Cupra, S.B.73, S3 AKR, s30tt, s5luf, sahar, SaneDave, sc1uk, ScoobyJawa, ScottHmk4, SCupra, Seal_LCR, SeanCorky, seat-leon2013, seatchry, Seatmann, seattoledotdi, seat_lion, sebby225R, SeRgI_GsI, sexyflanders, shadydaverave, shaker, shaneseat, shaneth, sheffboy, shep0706, sheperd, Shunky, Si, SidewaysCupra, sie77, silvaR, simon14, SimonTemplar, singh123, SirSuraj, Si_TDi_FR, sjolliff, slater, slim, Slimy, SM, smighall, Smiler-MK2, smoothuk, sniperftw, sockpuppet, Sonic1506, Soulfinger, SpiroSFR, splitpin, sprite, staza, SteveCl, SteveRyan, Stiva, STOCKY, stpete, str8ballin, stuartsjg, stucupra r, stumack, stuy, stu_trousers, subby28, supersticky, swedey21, swilky23, swompz, szaakos, TAOTAO, taph, tarzan, taz95, TazB, tballt, TDCupra, tdi_swedge, tdi_will, The Ham, Theresias, thewiizard, the_fbi, THFC, thomasa, timbland181, TimJK, timothy5858, Ting, Tiz, tolis68, Tolly 150, tom w, Tomer 20VT, tonycane, top0cat, topsport1976, Toxic, treborleon, Tucker157, turboboy111, turbotim, turbo_scotty, Tuvix, twenny, twin2189, TwoZeroAlpha, TWR_Jaguar, tyrrell, Uncle Fester, Undert4ker, urbanracer8, VAD@HPA, VAG Diesels Rul, Vapour-Trails, Vaughny, Victor_Cupra, Viking, vladislav, vstuning, vw-aj, W11TTX, walsh91, wardy2602, was225, wc76, WeeG, welty, werdna, wezy0, whitbytom, Wiggy20, wild willy, WildChild88, Willie, Willxr, wisejason, Wolvotim, x!co, x-Ecutor, xreyuk, Yak, YIN, Yohan87, Yosh, zach225, zan, zarkov, zilcho, zyxelcf, _chris_, __B3NNY__
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Website © 2013 SEATCupra.net
Disclaimer: SEATCupra.net is not an official SEAT site and is not affiliated to SEAT in any way. Visit the Official SEAT Website.
SEATCupra.net are not directly responsible for information which maybe posted in this forum.
All content is viewed and used at your own risk. We do not warrant the accuracy or reliability of any of the information.
The views expressed herein are those of the individual contributors and not necessarily those of SEATCupra.net or SEAT
All trademarks and copyrights remain property of their respective owners.
