| Forge Motorsport Manufacturers of VAG Turbo tuning accesories Custom build intercoolers , Diverter valves , Blow off valves , Forge Silicon Hoses by siliconhoses.com |
#1 |
Posts: n/a
DV007, which colour/softness?
Hi all, i notice on westec's site, there are a couple of choices for the FMCL007P
Fast Road Closed Loop Diverter Valve See here: http://www.westecperformance.co.uk/a...er_valves.html at the bottom it has, green, yellow etc, and a tuning kit, i have an ibiza cupra and wouldl ike to know if this is suitable and which version? thanks, i have searched btw, but no reff to colours
#2 |
FOOORRREEE!
http://www.seatcupra.net/forums/show...ghlight=spring
yellow it is!
__________________
Estoril Blue BMW X5 4.6IS Shiney Flash Red 2004 Leon Cupra Now Gone , if anyone wants it, I can put them in touch with the guy selling it, Heathrow direction.
#3 |
Posts: n/a
ty
, one more quick question, do i need the version with the moving top? excuse the technical term. as ive heard many people have trouble fitting them without them fitting flush?Thanks a bunch!
#4 |
FOOORRREEE!
moving top?
i found the shiney 007p fitted fine.
__________________
#5 |
Jack-RIP my little Friend
I still dont understand why stiffer springs are needed...
25psi of boost on mine, std green spring on 007P, tested to 30-psi static load and no leak. I have tried stiffer to see, but if anything it made for a stuttery surge on lift off, or when too much, wastegate chatter from compressor stall. (break turbo in the long run) i guess you can get your tuning kits and play to see how you like em.
__________________
![]() BADGER 5 LTD: PERFORMANCE TUNING RACE PROVEN PRODUCTS & HONEST ADVICE: Contact:07976 800775, 01453 827936,Fax-0870 0561360 Bespoke Big Turbo conversions,DevilsOwn WMI,Forge,Ferodo,AP Racing Brakes,Custom Code,REVO,H&R,Eibach,KW,Koni,Milltek,Jetex,Vibratechnik,Compmotive,DTA,Jenvey,Brembo brake kits,EBC,Koni,Neuspeed, and much much more... http://www.badger-5.com email me at:bill@badger5.co.uk |
#6 | |
Quote:
__________________
Rich. Skoda Octavia RS |
#7 |
Senior Member
I run a 007d with stage3 ihi and i use the weakest spring. I get less wg chatter with this spring. I cant remember the colour.
__________________
Big Turbo Mk3 Ibiza Cupra |
#8 |
Back in the S!
My dv006 came with a blue spring as standard.
Anyone know if that is stiffer or softer than the green??
__________________
#9 |
CruisinUK.com
I have a quick question, is there any different between a FMDV007P and a FMCL007P?
Is the CL007P the newer version?
__________________
>> My 2001 Ibiza Cupra - Ovni Yellow << ![]() Custom Code Phase 1 : Forge TIP : Blueflame Turbo Back System / FK Highsport Coilovers : 17" Pro Race 2 Alloys - Gloss Black : Green Dynatwist : Forge FMCL007P : Lester De-badged Grille : LCR Front Splitter : Customised All Red Rear Lights : Polished Bonnet Lifters : Nomad A Pillar : Autogauge Boost & Oil Temp Gauges : Coming Soon: New Brakes! Bodywork >> WANTED - Mk3 Ibiza Brembo's!! << >> WANTED - Mk3 Ibiza Strut Brace!! << FOR SALE - Standard Mk3 Ibiza DP/Cat |
#10 | |
Acceptable in the 80s
Quote:
__________________
Mark 2008 Leon Cupra ![]() 2005 RICA Volvo V50 2.0D Sport 2003 revotechnik Leon Cupra R |
#11 | |
Punxsutawney Phil
Quote:
Green (standard/as supplied unless you ask for something else) Yellow Blue Red. I have the Blue one in. If you want to "tune" and don't have a kit - stick some washers in...
__________________
Phil |
#12 |
Your scaring me.......
I have just order a Forge 007, but i opted for the Medium - Yellow, cause hopefully in the future i will be fitting dynatwist and finally get a splash of REVO.
Ive got a new LCR with no other mods, so have i done wrong by buying a Medium and not a soft ?? If so, i think i might send it back and get the replacement Last edited by Empi5; 09-03-2005 at 14:18. |
#13 |
Empi
The yellow will be fine on your car . The tuning kit will allow your valve to be configured to your own personal preference. We have some alloy shims available if anyone needs them rather than putting in washers. |
#14 |
Back in the S!
I now run a blue spring and 1 shim in my dv006 after it was leaking when revo'd with just a blue spring.
__________________
#15 |
Yellow for me and it runs fine.
__________________
| Bookmarks |
| Tags |
| colour or softness, dv007 |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
(View-All)
Members who have read this thread : 2
| cupramillo, sie77 |
| Thread Tools | |
| Display Modes | Rate This Thread |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Forge DV007 - help fitting ! | nugget | Problem Issues Q&A | 7 | 01-08-2004 18:25 |
| DV007 and Dynatwist | NOSman | Ibiza Mk3 | 8 | 26-06-2004 17:18 |
| forge dv007 - what r the | dannyleonturbo | Leon Mk1 | 20 | 27-05-2004 09:17 |
