| Ibiza Mk4 For the 2002 - 2008 model |
Thread Tools | Rate Thread | Display Modes |
#1 |
SNAFU
Gear lever surround/Gear knob
Ok, i've just bought a new gear knob, now i just have to fit it.
I did a search and came up with these instructions: "lift up the gaiter skirt to get access to the copper ring which hold on the standard knob. using a screwdriver, prise the copper ring off and pull away your standard gear knob and gaiter. remove the plastic ring holding the gaiter and knob together. Take the new knob and insert screwdriver into the gaiter retaining ring. It should just pop off. the new knob then needs to be attached to the standard gaiter. Attach it in the same way it was attatched to the VW one. Pop on the new knob and crimp the copper ring to hold it in place. Refit the gaiter. Job done in less than 5 mins" In order to lift up the gaitor I need to remove the surround, so how do I do that or am i just being thick? Thanks in advance
__________________
Ovni Yellow SEAT Ibiza TDi Sport 130 (with optional buckled and chipped wheels, birds*it paintwork, creaky suspension, dodgy air con and too many miles on the clock)
#2 |
Full Memba
easy job mate even thought i know it seems daunting. my guess is u've bought a momo nob or sumthin similar so heres how to go about it:
1. run your finger over the top edge where the leather gaiter meets the plastic surround and u sould feel two bumps. pull them up as they are clips. 2. the whole gaiter plus surrounds on top and bottom will lift up. pull the gaiter upwards till u see the bottom of the original knob. 3. prise off the copper ring (******* of a job) and twist and pull off the knob. 4. Fittin A New Knob- most aftermarket knobs come with instructions so use them. most probably will have to put on a rubber 'hat' on the top of the gear stick shaft. 5. place knob over rubber top bit and screw in grub screws. 6. replace whole gaiter + surrounds and bob's ur auntie! hope it helps clipse
__________________
Ibiza 1.2- aqua green 17" Lenso Reisen rims on Nankang NS2's Fusion 12" sub and amp /////Alpine CD/mp3 headunit Colour coded, aluminium gear lever surround, strut brace, FR grilles Newly Fitted- Powerflow custom 5'x3' exhaust, LCR splitter, black+ tinted rear lights, dynamat'ed,Green cottton induction kit with pipercross cold air feed leads to --->
#3 | |
SNAFU
Quote:
Great instructions mate, even though it's dark outside it didn't take more than a few minutes.
__________________
#4 |
Full Memba
no probs mate, glad i could help. hopefully u've now got the moddin bug as i was diagnosed once i had put on a new knob. now goin the whole 9 yards on my car. get sum aluminium gear lever surrounds next, looks top with a new gearknob.
clipse_t
__________________
#5 |
Still having trouble with my gaiter. Doesnt fit under the Momo knob that i got on, so is just flapping around the bottom of the knob
__________________
Mk2 Fabia VRS |
#6 | ||
SNAFU
Quote:
Quote:
__________________
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
(View-All)
Members who have read this thread : 28
| ant49, bubbles1, Chocozai, DanDiesel, deadlydave90, es, fletcher, ibiza64, jcskinny, jhono, Jmaes5926, Joey350, jwilkinson, knox102, Loopy 001, Maleko, matfennell, n2o, Ninety, nvidia, rallyleon, reidzer2272, rocky2008, six6sicks, stezo2k, tom167, Travezy, white blood |
| Thread Tools | |
| Display Modes | Rate This Thread |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| gear knob question | chris285 | Ibiza Mk2 | 4 | 24-01-2005 12:29 |
| New Gear Knob | W99DEY | Mk1 & 2 Toledo | 0 | 28-07-2004 20:18 |
| ibiza cupra sport gear knob | pwleicester | Guides | 3 | 15-03-2004 19:32 |
| Sequensial gear change? its possible! | primekart | Leon Mk1 | 1 | 09-01-2002 16:25 |
| Gear shift knob | cupra-cymru | Leon Mk1 | 3 | 17-12-2001 21:46 |
