Chris Knott
Go Back   SEAT Cupra.net - SEAT Forum » SEAT Model Specific Discussion Forum includes Members Projects » Ibiza » Ibiza Mk4
Ibiza Mk4 For the 2002 - 2008 model
Reply
Thread Tools Rate Thread Display Modes
Old 23-03-2005, 15:35   #1
KWEV
KWEV's Avatar
KWEV has 10 points
Exclamation Ibiza Side Light Bulbs
Can anyone tell me the best way to change the front sidelight bulbs on a tdi 130 sport - twin bulb type lamps . It looks to me like headlight out jobbie - if so , does anyone know the dismantle sequences - if you know what i mean
cheers.
KWEV is offline   Reply With Quote
Old 23-03-2005, 22:34   #2
Stephen O
Stephen O's Avatar
Stephen O has 10 points
It can be done without taking the headlamp out, but it's very tight! Best way is to try and move as much stuff away from the back of the lamp i.e. battery cover's etc.
Oh and plenty of patience and cut hands!
Stephen O is offline   Reply With Quote
Old 23-03-2005, 23:11   #3
Fl@pper
Cruising with the 6 Pot..
Fl@pper's Avatar
Location: Easy life Cruise control with 200bhp of Bavarian RWD slushboxed Leather Comfort :)
Fl@pper has 10 points
long nose angled pliers are my favourite
**tip** DONT pull the wires - they will break out needing a repair if you do
once they are in/out twice they are loose as anything
__________________
Fl@pper SouthernPikeyBigEaredHotRoddingIronMaidenMetallicaFan@e-parts.co.uk
Fl@pper is offline   Reply With Quote
Old 27-03-2005, 11:54   #4
KWEV
KWEV's Avatar
KWEV has 10 points
Thanks for the info guys
cheers
Old 30-05-2005, 18:41   #5
EddyH
EddyH's Avatar
EddyH has 10 points
Any further tips on this? I have small hands and I still can't change the sidelight bulbs.
__________________
EddyH
S8
A3 2.0TDI Sport
EddyH is offline   Reply With Quote
Old 30-05-2005, 18:45   #6
Fl@pper
Fl@pper's Avatar
loosen off and move the battery away a bit will help a bit on one side but to be honest never had trouble with the LONG reach pliers and one hand in there - watch your fingers as a pinch off em hurts ! ! - trust me -
another tip - dont mess with it too long with your hands in there - done a ford ka last week and nearly got my hand stuck
__________________
Old 30-05-2005, 18:49   #7
EddyH
EddyH's Avatar
EddyH has 10 points
Quote:
It's the other side I'm struggling with as there's some sort of cannister in the way (PD130 engine).
__________________
EddyH
S8
A3 2.0TDI Sport
Old 30-05-2005, 18:51   #8
Fl@pper
Fl@pper's Avatar
probably the aircon drier ? or even the fuel filter housing - got any pics ??
__________________
Old 30-05-2005, 19:04   #9
EddyH
EddyH's Avatar
EddyH has 10 points
Here you go:
__________________
EddyH
S8
A3 2.0TDI Sport
Old 30-05-2005, 19:17   #10
yellowperil
yellowperil's Avatar
yellowperil has 10 points
Thats your fuel filter mate, think it will slide up out of the black round bracket if you loosen the fastener, dont pull at pipes to much though
__________________
MK2 Leon FR TDI Luna Grey
18's, Bluetooth, Full Aero Body Kit, Chipboost remap, whats next?
yellowperil is offline   Reply With Quote
Old 30-05-2005, 21:48   #11
EddyH
EddyH's Avatar
EddyH has 10 points
Managed to do it with removing the fuel filter.
Now how do I get the rear light housing the indicator and brake light out as one of them has blown. The manual says to remove the 2 screws and then pull the pilot! I've no idea what it means and having no luck removing it.
__________________
EddyH
S8
A3 2.0TDI Sport
Old 30-05-2005, 22:24   #12
qifop
DuH!
qifop's Avatar
qifop has 10 points
Remove the 2 screws then pull like hell. They are really tight. Like the front bulbs, once in and out a few times they soon loosen up a bit...like most things in life....
__________________
[SIZE=3]03' Ibiza 1.4 Sport (100bhp) - Black Magic[/SIZE]
[SIZE=2]Mods - 6000k HID Conversion & K&N Replacement Air Filter Element[/SIZE]
oh... and SCN Window Stickers
qifop is offline   Reply With Quote
Old 30-05-2005, 22:28   #13
Fl@pper
Fl@pper's Avatar
loads of room in there m8 glad ya sorted though
__________________
Old 30-05-2005, 23:07   #14
EddyH
EddyH's Avatar
EddyH has 10 points
Thanks for the help. Not got the rear light off yet, the car was moving more than the light unit.
__________________
EddyH
S8
A3 2.0TDI Sport
Old 31-05-2005, 09:13   #15
muddyboots
Still hanging around
muddyboots has 20 points
Quote:
I'll second that - they are *really* tight to get out, so much so you think you're going to break something. The front edge of the lamp housing has got a big beefy clip holding it into the body. Best of luck, hope nothing breaks !
muddyboots is offline   Reply With Quote
Old 31-05-2005, 09:15   #16
muddyboots
With regards to the headlights - if you want to remove them, it's a bumper-off job (which isn't that hard, takes about 10-15 mins once you've worked out where all the screws are. Oh and they're all torx-headed screws too ;-) ).
If you have the factory Xenons like me, this is the only way to get your main beam bulbs out (and the dipped discharge bulbs - but they should never go in theory...)
Once the bumper's off, each headlight is secured by 4 torx-headed screws (2 top and 2 bottom).
A good idea might be to get the bumper off, remove the headlights, and replace all the side & indicator bulbs with LED versions that should never blow.
Old 31-05-2005, 16:40   #17
EddyH
EddyH's Avatar
EddyH has 10 points
Quote:
I don't seem to be able to get a good enough grip on it to pull straight back. I'll have another a go tonight as it was getting dark when I tried last night.
__________________
EddyH
S8
A3 2.0TDI Sport
Old 01-06-2005, 00:49   #18
Angusrob
Angusrob has 10 points
as a last resort U can get at the clip from the inside if u take off the interior trim and peal back the carpet. A pair of needle nosed pliers pinching the clip helps it come off with ease.... but u do have a fair bit of plastic trim to remove first!! Mine was a stubborn B***h to free. U'll manage and after a few tries like qifop said they loosen up.
__________________
03 Ibiza TDi 130PD Sport
Angusrob is offline   Reply With Quote
Old 01-06-2005, 09:47   #19
EddyH
EddyH's Avatar
EddyH has 10 points
Sorted it last night, the problem I had was the black plastic lip was catching on the body work. I used a wide bladed plastic scraper to lever it round and off it came.
__________________
EddyH
S8
A3 2.0TDI Sport
Old 01-06-2005, 15:43   #20
IainW
Senior Member
IainW's Avatar
IainW has 10 points
My driver's side sidelight needs changing as well. I bought a bulb, opened the bonnet and tried fiddling with it for about 10 minutes before giving up. I'll have another crack at it when it's not raining. Which may be some time.....
__________________
#1: 04 Ibiza 2.0 Sport, #2: 06 Ibiza 1.9 FR TDi; #3 07 Leon 2.0 FR TDi; #4: 13 Leon SC 1.2 TSi SE; #5: 15 Leon 1.2 TSi SE; #6 14 Leon ST 1.6 TDi SE Ecomotive
IainW is offline   Reply With Quote
Reply
Bookmarks
« Previous Thread | Next Thread »
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
(View-All Members who have read this thread : 221
20 valve ted, 306Chris, aanev, Ac2709, Acksaw, adamdanshona, Alex 17, andreww, Andy ap, andy17, ANDYH1966, Andyy, AP2000, Arkaig, Arnoldo, ASHY7777, Ash_238, Avim28, b1nuzz, bald_eagle, beezajono, belfastchris45, BHP Addict, binkylad, black_fr_07, bodysnatcher, bogdancristiann, bradpalmer, Brady93, broadbandings, C50, Cal91, CGD217, chief_kris, Chino_UK, chrisduke, chrisjm29, Chris_a_73, churcherj, CJRamze, CJS-90, claffey_, coronah, Cos, Craigbarnley, Crashapollo, creatz, cupra!, cupra.al, CupraJimbo, Curtiz, DanLewis1991, dannychapman10, Dan_T, Davidsr, dawnibiza, daytona246, Dazz 1989, dc98ddc, DEAN0, Deano2316, dervpower, dirtyD123, DKershaw, Dom1988, DonniD1991, dunjamon, ecklad, ecosse1986, F@ruk, flegz16, forever, foxie2, fr930, FR_POWER, garethgje, gazbrum, george130, Gizza, GlanzaV, GPL, Graemeb_dj, Guffers, Gunni, gunsdontkillppl, gus, H1JJY, Hardcore, harddiillion, higgi, Hudson, iain1970, IanG, Ibia FR 1.8T, ibiza@kev, IbizaC, Ibiza_Oz, IBIZA_W1LL, ijeffery, Jack1991, JaCko93, Jake949, james12, Jamesemt, Jbuck93, jebus, Jimmy-james, John11367, Johnsbegood, Jon.ibizafr, JonnyPostill, JPS3290, JR750, JR_130, JU5 2 SLY, Keir, kidinspace, Kie183, killbill, knight85, L16JAY, Lewis55, Lippo, littlejon, lm_92, louise ibiza re, Lowe, luke_cafc4, malky39, marcussss, Mark300zx, Mark_Karting, MartinDov, matt5964, Mattwood, Matty White, Maverick08, mc funbot, mcevoy85, MichalR, Mikey_P8, modd1uk, momiwi, Monks Seat, Mr Scubatank, muddyboots, Murray, Mustang2044, ndbrgr, neil72, Neo, NickyJam, Noddy_2k8, nozzy15, obou, Octane2097, OldSpeckledBen, orange, OvEr_KiLL, Pabs, Packham, PaulDAB, PH1L NI, PJ_TDi, platofan, PLuKE, qwert, Qwerty, R1ch85, racingsquirrel, Random1989, Raziel, Red Panda, reidy388, rf860, richard booth, robt880, rocky2008, Romigo, RpR, Ruthers, RyanBarber, Sano, Seat Adam, SheffieldKid, shep0706, Shivington, shox, simonthekane, skillaturbos, Skisbp, slicecbr, Slippery_Stu, Spooky211, Stebb, steslatt, stevoibizacupra, stonewales, Syy, tcm1106, TDI ste, tdi_swedge, TeeJay, thePHILosipher, Ting, tom167, truss, tweedz, vagfam1, Vibe, villian, vmark89, vroomtshh, weemanno1, Whitechapel, whiteknee, will7291, wrayvon, xxAaron, YorkIbiza, zach225
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Website © 2014 SEATCupra.net
Disclaimer: SEATCupra.net is not an official SEAT site and is not affiliated to SEAT in any way. Visit the Official SEAT Website.
SEATCupra.net are not directly responsible for information which maybe posted in this forum.
All content is viewed and used at your own risk. We do not warrant the accuracy or reliability of any of the information.
The views expressed herein are those of the individual contributors and not necessarily those of SEATCupra.net or SEAT
All trademarks and copyrights remain property of their respective owners.
