Integrated Engineering
Go Back   SEAT Cupra.net - SEAT Forum » Diagnostics, Tuning and Modification » VAG-COM & Diagnostics
VAG-COM & Diagnostics VAG-COM is a diagnostics program that allows your PC to talk to your ECU - All VAG-COM / 1551 questions to be posted here
Reply
Thread Tools Rate Thread Display Modes
Old 01-05-2005, 14:17   #1
J@mes
e46psi.com ;-)
J@mes's Avatar
J@mes has 10 points
Arrow Auto-Scan HELP....
today i used my vag com for the first time
first thing i did was made my alarm chirp which sounds good i think
however i came across one problem (yes iv searched! lol)... when doing an Auto-Scan, on a few controllers it didnt seam to be able to read it, said...
"Note: Cant Synch Baud Rate"
any ideas as to wat this means?
the reason y i got vag com was so i could check for fault codes on my car/engine etc!
here is a copy of what it said after i did an Auto- Scan...
VAG-COM Version: Release 311.2-N
Chassis Type: 1M - Seat Leon
Scan: 01,02,03,08,15,17,19,22,35,46,56
Address 01 -------------------------------------------------------
Controller:
Note: Can't Synch Baud Rate
Address 03 -------------------------------------------------------
Controller:
Address 08 -------------------------------------------------------
Controller: 1M0 820 043 E
Component: 1M-CLIMATRONIC X0702
Coding: 00041
Shop #: WSC 06403
No fault code found.
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller:
Address 19 -------------------------------------------------------
Controller:
Address 46 -------------------------------------------------------
Controller: 1C0 959 799 F
Component: A7 Komfortgerát HLO 0004
Coding: 00258
Shop #: WSC 06403
Address 56 -------------------------------------------------------
Controller: 1M0 035 186 K
Component: Radio GRO 3 30
Coding: 00401
Shop #: WSC 06402
End -------------------------------------------------------
so what does "Note: Can't Synch Baud Rate" mean??? i want to find out if i have any fault codes on my ecu/engine, but it seams i cant at the mo/i dont know how to.
any help would be much appreciated
cheers,
james
__________________
JABBA STAGE 2 LCR
13.8 @ 103mph (NOT fully stripped!)
J@mes is offline   Reply With Quote
Old 02-05-2005, 04:25   #2
Uwe@Ross-Tech
Uwe@Ross-Tech's Avatar
Uwe@Ross-Tech has 10 points
Most likely that means you're using a USB<->Serial converter, one which doesn't work well with VAG-COM. Try a different converter, a PCMCIA serial port, or a real USB interface. Note: Real USB interfaces do not "emulate" COM ports.
If you're plugged into a real serial port, it means you're using a really crappy interface...:-)
-Uwe-
Uwe@Ross-Tech is offline   Reply With Quote
Old 02-05-2005, 12:10   #3
J@mes
e46psi.com ;-)
J@mes's Avatar
J@mes has 10 points
"PCMCIA serial port, or a real USB interface...crappy interface..." sorry you have lost me a bit with the jargon!
basically i got a cable off a m8, and when i came to use it i noticed it wouldnt plug into my laptop
so i went to maplins and baught one of these (a usb serial adaptor)... http://www.maplin.co.uk/Module.aspx?...=29968&doy=2m5
it cost £20 and i knew i could get one on ebay for a lot less so i thought id get the maplins one use it on the weekend, then get my money back and buy one on ebay for a lot less!
last night i baught one of these on ebay (for £6.46)... http://cgi.ebay.co.uk/ws/eBayISAPI.d...765330243&rd=1
please tell me this usb serial adaptor will work? if not, can anyone show me a link to one that will?
cheers,
james
__________________
JABBA STAGE 2 LCR
Old 02-05-2005, 12:29   #4
J@mes
e46psi.com ;-)
J@mes's Avatar
J@mes has 10 points
just had another look at the difference in spec of the maplins usb serial adaptor i baught and the one i baught on ebay last night...
the ebay one supports usb 1.1 and 2 (maplins doesnt support usb 2)
the ebay one supports over 1Mbps data transfer rate (maplins one is 500Kbps)
would either of those 2 factors be a reason y the maplins one didnt work properly?
james
__________________
JABBA STAGE 2 LCR
Old 02-05-2005, 14:07   #5
Uwe@Ross-Tech
http://www.ross-tech.com/vag-com/faq_1.html#1.5
-Uwe-
Old 09-05-2005, 15:22   #6
SkaterNatty
sk8 4 life
SkaterNatty has 10 points
J@ames
Where in vagcom did you set the chirps to on? I had a quick look the other day but couldn't find it!
Also, does anyone have vagcom info on the mk4 Ibiza? I can't seem to find any anywhere... A service/heynes manual seems to be like finding rocking horse poop!!!
Cheers in advance!
SkaterNatty is offline   Reply With Quote
Old 09-05-2005, 23:38   #7
J@mes
e46psi.com ;-)
J@mes's Avatar
J@mes has 10 points
no heynes manual... heynes mk4 golf is an option tho.
i searched to find how to turn the chirp on
but stil... go to select control module, then click 46.Cent. Conv,
then you click adaption, then scroll up to about number 8 i think and change the 0 to a 1 and it will turn it on... you will understand what i mean when you get there
hope this helps!
james
__________________
JABBA STAGE 2 LCR
Old 11-05-2005, 10:55   #8
SkaterNatty
sk8 4 life
hope this helps!
james
Nice one dude. Once I spend a little time in front of it, it became clear what I was looking at. Now I chirp!
Cheers matey
Natty
PS - what side of the bed did QMA get out of?!
Reply
Bookmarks
« Previous Thread | Next Thread »
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
(View-All Members who have read this thread : 8
adam cupra 20vt, ddj1975, egypt, Greegiecee, mikejclark, Si_TDi_FR, sparkie1984, splitybus
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Auto closing windows herbert Leon Mk1 14 24-05-2007 22:17
Auto Headlight Activation Fl@pper Modifications and Tuning 12 03-03-2004 18:51
Auto dim rear view mirror Steve185 Leon Mk1 6 05-07-2002 23:20
Website © 2013 SEATCupra.net
Disclaimer: SEATCupra.net is not an official SEAT site and is not affiliated to SEAT in any way. Visit the Official SEAT Website.
SEATCupra.net are not directly responsible for information which maybe posted in this forum.
All content is viewed and used at your own risk. We do not warrant the accuracy or reliability of any of the information.
The views expressed herein are those of the individual contributors and not necessarily those of SEATCupra.net or SEAT
All trademarks and copyrights remain property of their respective owners.
