DPM Performance
Go Back   SEAT Cupra.net - SEAT Forum » Diagnostics, Tuning and Modification » Modifications and Tuning
Modifications and Tuning Information and discussion on modifications, Styling, Suspension upgrades, Brake Upgrades - you name it, it's here.
Reply
Thread Tools Rate Thread Display Modes
Old 12-05-2005, 11:49   #1
babaa
babaa's Avatar
babaa has 10 points
Installing new head unit
I've just found out that my new Sony head unit will be arriving in a week or 2, but so I don't have to stop and start the job of installing it once I get going, can someone just clear up a few quick questions:
1 - I've read that cutting up a credit card is the easy way to get the existing Aura CD unit out, but are the 2 slots that I push them into actually the holes about 0.5cm up from the bottom of the unit (one beneath the volume, and one beneath the 5 button), or should I be looking for slots literally on the underneath of the unit?
2 - In terms of keeping the cabling as simple as possible I was thinking of getting the following adapter kit http://www.nexxia.co.uk/head_unit_fitting_kits/seat.htm (the FKS 474 kit for £25). But am not sure whether the PC5-90 is the correct aerial booster I have read about needing, and also if I get this cable adapter do I need to do something (i.e. disconnect) the 'K line' or can I just plug it straight in and not worry about anything plugging in and going pop.
3 - If I need to mess about with disconnecting any wires, then can I also just swap 2 other wires over in the standard connector block (can't remember which off hand, but can have a search), and then totally do away with this part of the adapter kit altogether?
Cheers for any help/advice on this.
babaa is offline   Reply With Quote
Old 12-05-2005, 11:54   #2
Scotty_b
Leon Cupra 300R
Scotty_b's Avatar
Scotty_b has 10 points
Can i buy the arial booster anywhere? a si have the iso block and facia and i pick my radio up on saturday (hopefully)
__________________
WANTED - LCR front Recaros
Scotty_b is offline   Reply With Quote
Old 12-05-2005, 12:07   #3
Icecavern
ICE God
Icecavern has 10 points
Scott I have one spare, it's attached to the ISO adapter already but you could remove it if you needed to. You can have it for £10.50 all in if you like, PM me if you want it.
Pete
__________________
Project Cordy build thread
My Wedding Photography blogsite www.stewardsonphotography.co.uk
Icecavern is offline   Reply With Quote
Old 12-05-2005, 13:59   #4
Scotty_b
Leon Cupra 300R
Scotty_b's Avatar
I kind of need it this weekend. Is it seat specific or should most audi places stock it?
__________________
Old 12-05-2005, 14:02   #5
Icecavern
ICE God
I could pop it in the post first thing, be with you saturday then.
You might be able to get one at you're local halfords if they have one in stock.
__________________
Old 12-05-2005, 14:06   #6
Scotty_b
Leon Cupra 300R
Scotty_b's Avatar
HMMM not sure what to do if i can get one at any audio center (im goung to caraudiosecurity.com in totenham court road) to get it i will pick it up then to make sure i have it as our post is cr4p. But if there specific i may have it!
__________________
Old 12-05-2005, 15:02   #7
Icecavern
ICE God
phone em up and ask if they have one mate.
Pete
__________________
Old 12-05-2005, 16:07   #8
babaa
babaa's Avatar
babaa has 10 points
Question
Anyone got any answers to my questions at the top?
Old 12-05-2005, 16:18   #9
Icecavern
ICE God
Ooops sorry
Quote:
Yes the holes you are talking about are the right ones. I've got the pics for a howto on changing the HU but haven't finished it yet.
Yes that is the right kit, you won't need to worry about any extra wires with that kit, the loom adapter cable doesn't connect any that are important.
If you use the adapter you don;t have to swap any wires on the Stereo loom.
Pete
__________________
Old 12-05-2005, 16:23   #10
babaa
babaa's Avatar
babaa has 10 points
Thanks for that Pete.
So just to clarify the last detail - if I use the kit then I don't need to do anything with the 'K line' wire to stop the issues I have heard with it breaking people's VAG-COM?
Old 18-05-2005, 13:29   #11
CH_2003
CH_2003 has 10 points
Sorry to hi-jack the thread but I've got a Pioneer stereo that I had fitted in my old car and I'm wanting to fit it in my Leon. It came with it's own loom. Should I be able to use this instead of buying the loom from Nexxia. I'm gonna order the facia adapter anyway but don't want to order the loom if I don't need it.
CH_2003 is offline   Reply With Quote
Old 18-05-2005, 13:38   #12
babaa
babaa's Avatar
babaa has 10 points
After getting my Sony head unit fitted, I didn't end up needing the cabling adapter bit that I had bought after all.
The Sony cabling already had bullet connectors for the red & yellow wires allowing you to swap them round easily. I did still need the aerial adaptor/booster bit though, and struggled for a while trying to make the end of the blue wire from this fit the existing Seat connector block - until I noticed a small brightly coloured plug to slide out of the side to loosen up all the cable ends.
I suppose it comes down to whether you are happy, able to switch over the red/yellow wires on your Pioneer loom without any problems, and get the blue wire from the aerial connected in?
Only other thing I would say is that it didn't look like there was loads of spare room to fit the adapter if I did need to use it without things getting all squashed up/rattling about.
Old 18-05-2005, 13:43   #13
CH_2003
Cheers Babaa
It should be fine as I had to swap the wires when I fitted it to my Astra. I'll just go ahead and order the facia and the aerial booster thingy
Reply
Bookmarks
« Previous Thread | Next Thread »
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
(View-All Members who have read this thread : 12
Anders0n, brainbug100, cup22, DeeroTDI, dunali, Gaz13, Hairy, hamlyn, rohanvj, rowlers, Shaved Wookie, whiteythomson
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Running amp on original head unit lukegeorge Modifications and Tuning 1 30-01-2004 17:52
Lead from Head unit to changer Boggieman Modifications and Tuning 3 27-01-2004 08:25
Problems with head unit Tom B Modifications and Tuning 12 28-12-2003 11:51
Installing a standard head unit in an Ibiza Bezzer Modifications and Tuning 4 24-04-2003 09:51
Swapping CD Head Unit for Tape Head Unit mjm01 Leon Mk1 0 27-10-2002 16:05
Website © 2013 SEATCupra.net
Disclaimer: SEATCupra.net is not an official SEAT site and is not affiliated to SEAT in any way. Visit the Official SEAT Website.
SEATCupra.net are not directly responsible for information which maybe posted in this forum.
All content is viewed and used at your own risk. We do not warrant the accuracy or reliability of any of the information.
The views expressed herein are those of the individual contributors and not necessarily those of SEATCupra.net or SEAT
All trademarks and copyrights remain property of their respective owners.
