Dreadnaught
My 13k Leon has started slipping it's clutch at about 2000 rpm (Ok at 1500, slips from 2000 20 2300 ish, then fine afterwards). Was almost undriveable Monday, but as you'd expect it performed flawlessly for the dealer today. Mechanically, its as supplied from the factory with the addition of a dealer-fit cruise control.
As far as i can gather, there is no adjustment possible on these units - anyone know if that's true? if it is, the dealer's offer to look at it anyway would just have been a ruse to charge a bit for labour and do nothing i guess.
Clutches slip for 1 reason - not enough friction between the plate and the flywheel. This can have 2 causes - contamination or the pressure plate is damaged / not up to it (or i guess it's being driven beyond spec).
Anyone else got direct experience of this? I had a look here yesterday and it seemed there was a bit of it about, but the dealer says he's never heard of it happening before (he's only about 12, so i guess that's expected).
