SEAT Servicing
Go Back   SEAT Cupra.net - SEAT Forum » SEAT Model Specific Discussion Forum includes Members Projects » Ibiza » Ibiza Mk4
Ibiza Mk4 For the 2002 - 2008 model
Reply
Thread Tools Rate Thread Display Modes
Old 21-11-2005, 12:45   #1
dmjw01
Upstanding Member
dmjw01's Avatar
dmjw01 has 10 points
Bosch "Aerotwin" retrofit wipers - anyone tried them?
I'm looking to replace the wipers on my Mk4 Ibiza, and just stumbled upon a product I hadn't heard of before.
Bosch "Aerotwin" wipers look quite sleek and a lot less intrusive than conventional wipers. They don't have the usual system of spring-loaded supports that a conventional wiper has; instead the wiper rubber is attached to a single solid strip that matches the curvature of the windscreen.
According to the above link, they're now available as retrofit kits. But unless I've misunderstood something, it looks like you have to buy the kit that is specific to your particular car - you can't just buy the correct size like you do with normal wipers.
After a bit more Googling, I found this page, which quotes "Seat Ibiza [6K1/6L1] 03.93-", with an item number of "A 533 S" and an order number of "3397118902". But I haven't found anywhere in this country that sells them.
Has anyone tried these as retrofits on a Mk4 Ibiza? Where did you buy them, and do you recommend them?
Or failing that, does anyone have experience of using them as original equipment on a newer car? Are they any good?
__________________
David
And that's why...
dmjw01 is offline   Reply With Quote
Old 21-11-2005, 12:51   #2
Chemical Al
Trollied Member
Chemical Al's Avatar
Chemical Al has 10 points
have a read of this...
http://www.seatcupra.net/forums/showthread.php?t=61860
Chemical Al is offline   Reply With Quote
Old 21-11-2005, 14:38   #3
Ant FR
Ant FR's Avatar
Ant FR has 10 points
i'll only stick to standard seat stuff as all the others mess up.
But hang on till next spring and the facelifted Ibiza is coming with Aero wipers as per the Polo and Golf style ones.
__________________
EP3 civic type r in championship White
Ant FR is offline   Reply With Quote
Old 21-11-2005, 19:08   #4
dmjw01
Upstanding Member
dmjw01's Avatar
Quote:
That's a good point. With luck, it shouldn't be too hard to swap the wiper arms for the new ones - I'm assuming they'll be the special arms for the aero wipers.
__________________
David
And that's why...
Old 22-11-2005, 11:10   #5
Ant FR
Ant FR's Avatar
of course
__________________
Old 24-11-2005, 17:16   #6
Grapo
Grapo has 10 points
Aero wipers suck though. Well mine do
__________________
Mk2 Fabia VRS
Grapo is offline   Reply With Quote
Old 25-11-2005, 13:16   #7
Giks
Newbie
Giks's Avatar
Giks has 10 points
I've changed my wipers to Bosch Aero Twin on my LCR and what I get is 100 times better cleaning, plus they don't freeze at minuses and looks no doubt much much better than original.
no major changes needed (plug&play)
All you have to do is go to your local Bosch dealer and ask for Aero Twin on Audi A3/S3
Giks is offline   Reply With Quote
Old 23-02-2009, 00:19   #8
MarkWales
Senior Member
MarkWales's Avatar
MarkWales has 10 points
what part number is needed for leon cupra 2004 for these aero blades mine need replacing at the moment i have standard blades would like the aeroblades
are they the same as the mk4 golf as my cousin has a 52 plate golf gttdi with aeroblades as standard
thanks in advance
MarkWales is offline   Reply With Quote
Old 23-02-2009, 13:03   #9
Ric 2001
Need an ID-ten-T form
Location: Shaw/Royton (Depends On Where I Am In The House!)
Ric 2001 has 10 points
thanks in advance
Have a look here mate. http://www.wiperblades.co.uk/product...1&Class=ncv&c=
And no the part number is different for a golf and a leon.
I used retro-fit areo wiper from the above company and there fantastic.
__________________
Platinum Mk4 Cupra 1.8 20vt MY05 - Gone, But Not Forgotten
Ric 2001 is offline   Reply With Quote
Old 23-02-2009, 13:11   #10
tkjeeves
Korean oil burner!
tkjeeves's Avatar
tkjeeves has 10 points
have my retrofit Bosch aeros for 6 months now and still no issues to report, made it even with the freaky 2 weeks of snow/ice.
I have noted that even proper flat blades can miss patches (had a brand spanking new 58 mk5 Golf with the passenger wiper missing a patch on the driver's "important vision" area but the driver's wiper will then clean this up)
__________________
Old: 2005 Blue SEAT Ibiza Sport 1.4
New: 2008 Black Kia Rio 3 1.5 CRDi
tkjeeves is offline   Reply With Quote
Old 23-02-2009, 14:29   #11
Aimez
Evil woman of doom beware
Aimez's Avatar
Aimez has 10 points
On my second pair now had the others on a year may have lasted longer but I got impatient with the ice and did the sin of using the wiper to clear the ice and afterwards once made a horrible noise! Were a year old anyway so wasn't bothered about messing them up!
__________________
Mk4 TDI FR Readers Ride
Aimez is offline   Reply With Quote
Old 23-02-2009, 14:35   #12
Suze
VW (now skoda) queen
Suze's Avatar
Suze has 10 points
i've got these on my octavia. Got them from http://www.autobulbsdirect.co.uk
Suze is offline   Reply With Quote
Old 24-02-2009, 09:53   #13
Danneh
Banned
Danneh has 10 points
I've just baught some for my car. They look very good compared.
Now I should actually have wipers which work and don't ****ing splash everywhere >:{
Danneh is offline   Reply With Quote
Old 25-02-2009, 09:36   #14
Nath.
The Gentlemans Express
Nath.'s Avatar
Nath. has 100 pointsNath. has 100 points
Very good wipers, way better than the facelift ones that I spent a fortune on retrofitting.
I'm back to my original wiper arms now with the Bosch aerotwins and I'm happy
Nath. is offline   Reply With Quote
Old 25-02-2009, 09:42   #15
Gooner_Mike
Teaching the kids
Gooner_Mike's Avatar
Gooner_Mike has 20 points
I use them, highly recommended!
__________________
Gooner_Mike
Ibiza FR 1.8T old RR Thread
Citroen C4 VTR+ HDi current RR Thread
Gooner_Mike is offline   Reply With Quote
Old 25-02-2009, 09:43   #16
Danneh
Banned
Mine should be coming today
Old 25-02-2009, 10:03   #17
GlanzaV
I start fires!
GlanzaV's Avatar
Location: Glasgow (Live) Edinburgh (Work) Ayrshire (Haunt)
GlanzaV has 10 points
I retrofitted my MK3 with Polo Aero arms + Blades at a cost of ~£100 and they weren't noticebly better than OEM blades. Fitted my Girlfriends car with retrofit (non-bosch) aero wipers and they work great! Although they are universal fit ones so the "box" that the hoop arm fits into is huge! But you don't notice it after a week or two!
__________________
GlanzaV is offline   Reply With Quote
Old 25-02-2009, 10:11   #18
Nath.
Nath.'s Avatar
Quote:
With the bosch ones the "BOX" that the hoop fits into is a lot smaller than most of the universal ones.
Old 25-02-2009, 15:21   #19
Danneh
Banned
Got the olde Areo Twin's on now.
It isn't perfect, though my screen is slightly an odd shape tbh.
But, certainly better. A clearer, quiet smooth wipe, and cleans the dirt and water very well. I'm happy, were slightly expensive though.
Old 25-02-2009, 21:30   #20
IainW
Diseasel Driver
IainW's Avatar
IainW has 10 points
So do these work fine with pre-facelift wiper arms? As I bought some supposed MK4 Ibiza blades from eBay early last year and they didn't fit the arms properly, but have now realised it could be because they were for facelift arms.
__________________
IainW is offline   Reply With Quote
Reply
Bookmarks
« Previous Thread | Next Thread »
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
(View-All Members who have read this thread : 258
-=Rob=-, 20darren03, A D Gee, Acksaw, Ads-ibiza, Aimez, ALEXZ360, alx_chung, anak, AndrewFabia, andreww, andy17, Andybon, andye1, AndyFM, ANDYH1966, andythom, AP2000, aq888, arf4n, Arnie, auto...emocion, AwesomeAl, BaggyHTID, basssound, beezanick, BHP Addict, Blakeyboo, bobak, bobfr, bobmcgod, boomhauwer, Boothy1979, Breezapom, brendanb1801, bubbles1, bukem, burnerg81, busa, Cainey, carlsoundwave, CELICA88, CGD217, chapelhill, CheesePie23, cheshmatt, Chewy cupra, Chris Maassen, chris4500uk, Chriswaite130, Chris_a_73, chris_leontdi!, Chrome, CJRamze, Conway563, CrossyR, ctarry, cudsy1, cupra.al, cuprakel, cupratdi-matt, Cupra_Jay, D3DNA, Damoegan, Danneh, darkhorse, Dark_V, DarrellW94, davered, davidmills2002, Davidsr, dervman, devonfr150, dgmx5, dicky FR, digimac, dionbee93, Disco_Biscuit, diss_50, djdorse, dmcar02, Dougy, ecklad, evo2345, excess, fat andy, Ferryman, Flems, fletch555, fozworth, fozzie, FR8ZER, Free Thinker, gabryell23, Gav-FR150, GazGT, gazR, george130, Gertie, GlanzaV, Glennolls, Gooner_Mike, Gubien, gus, halftone, highlander, Housey, Iain101, IainW, ibiza2003, ibiza64, ibizaqueen, ibiza_1.4tdi, ilikefatgirls, Irie, Iron_Maiden, jaamo, jamesbrit1, James_85UK, jaykay001, JayTse, jenk, JimmyL, JMann, joewl92, joe_ibiza, johnfbr, Jonny, jtonline, Judgejim21, K3mist, kez, kriso, KWEV, leejonm, leerooi, Leigh15, leighton, LewisW, Liam6871, lil3520, Lippo, LoDa, Lordhuberti, Lurch_Hull, magicoi, Mandip, Mantas, mark.pt, Mark300zx, markmeus, markthommo_84, MarkWales, Marmalizer, Mattwood, matt_s, MauriceRKK, mazzerati, mickeyp88, MiguelTavares, Mikael, Mikey_P8, Modelmakerman, mr_ice_uk, muddyboots, muddyfox470, mw5076, mymorph, Nam-uk, nanapez2, Nath., Nathan, nema, Neo, NickLCR, NickyJam, Nick_A, Nick_J, NinjaFlavour, Nkon, nph, number2, OldSpeckledBen, Parr17, paulhdi, PaulieB, Pepz, Pete Nov, Pete5956, Phil__Arosa, PJ_TDi, PLuKE, Pont, puchos, R1ch85, r2d2hp, RachIbiza, ren7, Ric 2001, ric25_78, rich td, robjonmogz, robokob, Ron Conno, Ronseal, ross_2787, rudeguest, RUM4MO, Russo, Russ_tdi, seantdi, seppuku, simonfouracre, Sjx, Skinny_uk, ski_tzo, skullmunki, Slippery_Stu, sonnyjemple, spannermonkey, specek, Spirit Furtive, spyke85, Sri Ryan, sssstew, stebbi, Steveod83, stezo2k, STPCG, stuplumpton, such, Sun_Tze, Suze, sydoggkdy, syko, t0m, T18_MPA, Tartan58, tdi_swedge, timmo666, tkjeeves, tolly_tdi, tom500, tred, Tricky Red, truCido, TSVB, Turboelvis, UncleFester, vincec79, vroomtshh, waitsey, will7291, wolfie150, wuciwug, x_hale, YorksIbiza, YorkUK
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Website © 2013 SEATCupra.net
Disclaimer: SEATCupra.net is not an official SEAT site and is not affiliated to SEAT in any way. Visit the Official SEAT Website.
SEATCupra.net are not directly responsible for information which maybe posted in this forum.
All content is viewed and used at your own risk. We do not warrant the accuracy or reliability of any of the information.
The views expressed herein are those of the individual contributors and not necessarily those of SEATCupra.net or SEAT
All trademarks and copyrights remain property of their respective owners.
