| Problem Issues Q&A A place for common issues affecting any specific SEAT issue, or tuning problems. If you have problems and are looking for answers this maybe a place to start. |
Thread Tools | Rate Thread | Display Modes |
#1 |
Newbie
Hazard Indicator Relay Switch
Hi All, I'm new to the forum so no mickey taking!
My indicators and hazards weren't working (Toledo year 2000) so I've purchased a new hazard indicator relay switch (other threads on here got me that far). Now I have the part I'm not sure how to remove the old one before I fit the new one. Is it a case of prizing the old one out with a screwdriver , or do I need to remove the radio and attack the hazard switch from below? Any advice gratefully received.
#2 |
Newbie
The answer is you pull the front of the switch off - I did this by opening the cup holder then using a screwdriver behind the switch. Once that's off you then shove a knife down the driver's side of the switch to release the metal prong, then shove a screwdriver down the passenger side of the switch and prize it out. Replace the unit and bob's your uncle, working indicators.
#3 |
Leon TDI SE lots of miles
Thanks for the post. I just had a similar problem, but gave it a jiggle at it seems to be working now. It sounded though the relay was sticking.
#4 |
Stage 2 Revo'd
My relay is the loudest thing in the car when i'm using the indicators i'm guessing this is normal?
__________________
My Car Did you not get a manual with your Leon, or want a .pdf copy? If my post has helped you click the scales to the left and leave me some rep points. |
#5 |
I spoke to soon! its gone again although alarm flashes seem to work.
Will replace it on the weekend |
#6 |
replaced it with part from VW garage in about 10 mins.
the relay is spookily quiet! |
#7 |
Stage 2 Revo'd
You got the part number handy mate please
__________________
#8 |
1J0953235J01C.
Its the same part for leon and golf mk4. VW colborne in Guildford just needed the last few digits. should be about £16. |
#9 |
Stage 2 Revo'd
Ta for replying
__________________
#10 |
Rubbing is Racing :-)
lee, did you try replacing this to make it quieter? i might indicate more if they weren't so loud..
__________________
Modded White Mk2 LC - Nurburgring BTG time: 8:25 http://www.seatcupra.net/forums/showthread.php?t=214599 SOLD!! |
#11 |
Stage 2 Revo'd
No mate, i got it out though, never did replace it, just got use to it tbh.
__________________
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | Rate This Thread |
