Awesome GTI
Go Back   SEAT Cupra.net - SEAT Forum » SEATCupra.net additional Resources » Frequently Asked Questions Section » Problem Issues Q&A
Problem Issues Q&A A place for common issues affecting any specific SEAT issue, or tuning problems. If you have problems and are looking for answers this maybe a place to start.
Reply
Thread Tools Rate Thread Display Modes
Old 10-02-2006, 15:15   #1
Beaker™
Slightly Unhinged........
Beaker™'s Avatar
Beaker™ has 10 points
Not Holding Boost?
What boost should my car be holding with REVO?
Swapped the boost gauge today for a different one which happens to be in PSI not BAR. Boost shoots straight up to 20psi, then drops quite quickly to around 12psi, this right?
As i'm sure the car was holding boost alot better before today. Feels different too, seems to run out of steam big time at around 5k?
__________________
******************** SOLD ********************
Beaker™ is offline   Reply With Quote
Old 10-02-2006, 15:37   #2
dannyk
leon cupra
dannyk's Avatar
dannyk has 10 points
Don't know what a revo'd lc should give you boost wise, but if i feals alot diff after you've fitted a new boost gauge, maybe you have a leak somewhere? make sure all conections are real tight and secure.
What were the 'readings' from the other gauge (BAR) b4 you changed??
12psi = 0.8 Bar
20psi = 1.4 Bar
Danny
__________________
dannyk is offline   Reply With Quote
Old 10-02-2006, 15:44   #3
Beaker™
Beaker™'s Avatar
Mmmm, i used all the existing piping so shouldnt be a leak there?
__________________
Old 10-02-2006, 15:47   #4
Beaker™
Beaker™'s Avatar
Pretty sure it was holding at 1bar before.
Will stick the old gauge back in tomorrow and see whats what
__________________
Old 10-02-2006, 15:47   #5
dannyk
leon cupra
dannyk's Avatar
Quote:
Originally Posted by Shifty-Shifty
Mmmm, i used all the existing piping so should be a leak there?
Maybe on the back of the gauge? or maybe a faulty one?
Maybe worth trying the other one (BAR) back in for a run to see what like.
Danny
__________________
Old 10-02-2006, 15:57   #6
acidstrato
My Fast says shut up!
acidstrato's Avatar
acidstrato has 10 points
shouldnt drop off 1bar/14psi
__________________
beezer cupra turbo Arctic - GONE....NOW - Milano Civic Type R
acidstrato is offline   Reply With Quote
Old 10-02-2006, 16:19   #7
andycupra
status subject to change
andycupra's Avatar
andycupra has 60 points
what car is it?
leon cupra?
sounds normal to me.
should be up near 20psi at full boost then fairly quickly but smoothly reduce down to about 12 at high revs
__________________
S.K.W.K.L.B.O.F H.K.S.K.P.P.P.
andycupra is offline   Reply With Quote
Old 10-02-2006, 18:04   #8
Beaker™
Beaker™'s Avatar
Its an Ibiza Cupra, just put the old gauge back in and at 1st it was still doing the same thing ie shooting up to just over 1.5bar then dropping quite rapidly to around 0.8bar But after driving 30mins it seems ok. So maybe the gauge was at fault i don't know.
Seems to be holding between 1.0/1.5bar now in 3rd 4th & 5th. Drops off quite quiclkly in 1st & 2nd though, but thats normal right?
__________________
Old 10-02-2006, 18:07   #9
acidstrato
acidstrato's Avatar
yeah drop off at around 5k is normal, although after having the forge TIP fitted today, the drop off isnt as noticable as it was
__________________
Old 10-02-2006, 18:09   #10
Beaker™
Beaker™'s Avatar
Quote:
So it seems as everything is as it should at the mo. This is good Will see what happens over the weekend
Cheers guys
__________________
Reply
Bookmarks
« Previous Thread | Next Thread »
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
(View-All Members who have read this thread : 5
krisbutler02, Mo Arif, neto, pinotattt, rob321
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
What the N75 valve does... Tazkenny Engine Discussion 27 22-06-2010 22:26
not full boost?! davidol REVO Technik Tuning 20 17-01-2006 21:10
Boost problem on K03S Damo Ibiza Mk3 19 16-11-2005 12:09
Ticking boost gauge... help!!! J@mes Leon Mk1 14 01-06-2005 22:16
Website © 2013 SEATCupra.net
Disclaimer: SEATCupra.net is not an official SEAT site and is not affiliated to SEAT in any way. Visit the Official SEAT Website.
SEATCupra.net are not directly responsible for information which maybe posted in this forum.
All content is viewed and used at your own risk. We do not warrant the accuracy or reliability of any of the information.
The views expressed herein are those of the individual contributors and not necessarily those of SEATCupra.net or SEAT
All trademarks and copyrights remain property of their respective owners.
