| Problem Issues Q&A A place for common issues affecting any specific SEAT issue, or tuning problems. If you have problems and are looking for answers this maybe a place to start. |
Thread Tools | Rate Thread | Display Modes |
#1 |
IBIZA Mk3 1.0Ltr MPi
Hi. Does anyone know what sensors work and report back to the ECU at the stages of starting up the engine from cold to Normal Temperature?
I have a feeling that I might have a faulty sensor (hoping its not an ECU problem!) as I have problems at about 5 minutes into a journey but only when the engine is started from cold. The engine 'kicks'/misfires once' as I say only happens when engine is warming up. Doesn't do it if engine is already warm and I go out in the car - very strange. Also what sensor(s) send back info to the ECU to say that its warmed up enough to turn the choke or fast idle off (if it were a normal carburettor engine but it isn't!) because maybe this is faulty. There is one sensor on the drivers side underneath the Throttle Body and its going into a black plastic housing its held in by 2 torx screws what does that do? its about the best I can explain it at the moment. Next time I get a moment I will take a photo of it and post it up on here Any advice please on any of the sensors? - I wish I could get a Haynes workshop manual on these car but unfortunately they don't produce one saying that they don't produce manuals if the car has not sold enough quantity to make it viable to bring out a manual! My car: Mk3 SEAT IBIZA Bog standard 1000cc MPi (multipoint Injection Engine) Year 2000. |
#2 |
sarcasm comes free
it'll be the coolant temp sensor, not sure where it is on the 1.0, but if it's faulty it will log a fualt code, and may show an engine warning light.
try following the coolant pipes back to the engine & look fot electrical connectors going into it.
__________________
#3 | |
Quote:
I bought a new temperature sensor/sender unit from SEAT's put it in myself and that sorted the gauge out and stopped it mucking about. There wouldn't be another coolant temperature sensor lurking somewhere else on the engine would there???? |
#4 | |
Quote:
Its got a Bosch part number on it: 0 261 230 031 inside the cage bit its got like a kind of ceramic like temperature component If this sensor was at fault could this be sending back wrong info to the ECU and making the car act up as its warming up? If I had to replace this do you reckon its an expensive sensor - will one from a scrap yard do? Thanks, Andy.
#5 |
sarcasm comes free
Inlet air temp, or manifold air temp sensor that is.....
If it's faulty it will log a fault - shouldn't be too dear at all really
__________________
#6 | |
Quote:
If its just this G28 sensor only that is at fault I cant understand why the engine only plays up when the engine is going from cold to normal temperature only. Andy. |
#7 |
sarcasm comes free
Clean the connector, reset the fault code & I bet all will be well.
__________________
#8 | |
Quote:
thanks, someone else mentioned that once. I did have a look once but could not even bloody find the G28 sensor! Can you see it from the top of the engine with the bonnet up or do you have to get to it from underneath the car do you know? Thanks. |
#9 |
sarcasm comes free
standing in front of the car.
It will be on the lower right side of the engine block, very close to the gearbox - it will take it's readings from teh crankshaft. it might be worth removing the sensor & cleaning it up a bit - when mine logged that fault it was all covered in bits of steel shards that had been drawn to it. I also WD40'd all the connections I could. best to get at it from under the car, most likely obscured by the front engine mount.
__________________
#10 |
engine coolant temp sensor & coolant temperature sender are two different things.The first sends a signal to the ECU for fuelling purposes,the second makes the temp gauge work.
#11 | |
Quote:
So do you reckon I have 2 coolant sensors on my car then? - the one I have replaced is at the top of the engine near the ignition coil. Although it looked like 2 sensors could fit into the housing there one was blanked off and the sensor was in the other one. with the funny black plastic U clip that holds it in! |
#12 |
let engine warm up then disconnect sender, if temp gauge drops down then you have got wrong sensor-this only operates the gauge
disconnecting the coolant temp sensor while the engine is running will usually put the engine management light on |
#13 | |
Quote:
#14 | |
Is this where the Crank sensor is?
Quote:
#15 | |
Audi Techie
Quote:
Is it a single cylinder missfire like ignition?I have known coils to short to the body at certain temps then be o.k when warm |
#16 | |
Quote:
Could be although nothing showed up on the garages diagnostic machine about the coil when they checked it. The only faults logged was G28 implausible/intermittent and battery voltage too low (although I had the battery disconnected for a while so that could have been that problem) |
#17 | |
Audi Techie
Quote:
It does sound like it would be the crank sensor if it's come up as a fault code your picture is a bit hard to see but it does look in the right area. |
#18 | |
Quote:
#19 | |
Quote:
#20 |
I removed this sensor off the engine as well whilst I was at it today. I am almost sure this is called the Knock Sensor but some people call it an Engine speed sensor. Its a bit grubby and I will clean it up now its off but does anyone know what effect it would have on the car if it had a fault?
Could it cause the engine to cut out a few minutes of Idling on the drive or cause the engine to cut out a few minutes into driving when the engine is warming up? ![]() |
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | Rate This Thread |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Reversing sensors | s22jcd | Leon Mk2 | 23 | 05-07-2006 22:03 |
| stuttery engine, then switches off!! | GTI 16v | Ibiza Mk2 | 6 | 02-02-2006 14:39 |
| engine oil | cu51pra | Ibiza Mk3 | 8 | 02-02-2006 08:42 |
| Cupras - engine cover | PaulD | Ibiza Mk3 | 20 | 30-01-2006 09:28 |
| Engine trouble. | carlt | Ibiza Mk2 | 6 | 11-03-2004 18:56 |
