Chris Knott
Go Back   SEAT Cupra.net - SEAT Forum » SEAT Model Specific Discussion Forum includes Members Projects » Ibiza » Ibiza Mk2
Ibiza Mk2 For VW Group 1993-1999 Discussion (including Pre & Post Facelifted Models)
Reply
Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Old 20-03-2006, 01:28   #1
Nick Cupra R
Nick Cupra R's Avatar
Nick Cupra R has 10 points
SEAT Immobiliser problems?
I’ve just got myself a nice tidy Mk2 Ibiza 1.8 16v GTi as a runabout. I'm having some problems with the SEAT immobiliser. The car has a fancy after market alarm / immobiliser which is working fine but the SEAT immobiliser is still operating and causing problems.
Sometimes the car will start but cut out after a second, after another attempt the car normally starts fine. The other day it just wouldn't start at all. I tried locking the car up again and unlocking it as well as many other different ways of alarming and disarming the car but all to no effect. I even tried disconnecting the battery for a while and reconnecting it hoping something would reset itself but this still didn't help. I plugged VAG-COM in and it came up with an error something along the lines of "car failed to start due to immobiliser". I reset the error codes and it started on the second attempt and the error reappeared.
The key I have is new non-SEAT key which was cut as the previous owner thought he had lost the original SEAT key so he had the immobiliser and key all re-programmed at SEAT. Could this be the problem? Could it be a loose cable? I do have the original SEAT key which was found after getting the new one, but unfortunately it is no longer matched with the car's immobiliser so does not work. Trying this key actually does exactly the same thing as when I have the problem; the car starts for a second and then cuts out.
Any suggestions?
__________________
TVR T350c | Mk2 SEAT Ibiza GTi 16v | SEAT Leon TDI SE (with REVO)
Nick Cupra R is offline   Reply With Quote
Old 20-03-2006, 08:19   #2
m0rk
sarcasm comes free
m0rk's Avatar
m0rk has 100 pointsm0rk has 100 points
Hi
I managed to replicate the fault by disconnecting the immobilser yesterday.... startd, died after a second or so, then wouldn't start again.
could well be loose connections the key barrel to ECU wires looked pretty crappy
__________________
[/right]
m0rk is offline   Reply With Quote
Old 20-03-2006, 11:02   #3
Nick Cupra R
Thanks Mark, as I expected from what you said on Saturday to be honest. Where is the immobiliser located? Is it a little black box somewhere near the steering column?
__________________
Old 20-03-2006, 11:38   #4
m0rk
sarcasm comes free
m0rk's Avatar
Yup - remove the glove box panel, unscrew the plastic shield underneath the steering column
The box is behind the dashboard, to the right of the steering column. I'll try to remember to get some pics tonight.
__________________
[/right]
Old 20-03-2006, 16:46   #5
GTI 16v
Posts: n/a
Hi there nick, nice to know Im not the only one!! I have the same problem on my 1.8 16v.
However I dont think the problem is with your key as I have the standard SEAT key and my car still has the problem.
A alarm specialist told me it happens more in the warmer months he said it could be something to do with the starter motor or alternator. I think it could also be distributor. But Im no mechanic.
Does your car also switch off when you depress the clutch (rarely) and hesitates at first on accelration??
I put a diagnostic machine on my car and came up witha fault code reading which was for a 'KNOCK SENSOR'. I know how to change this part, but its hard to get one. Wondering if you had this problem. Not too many have the 1.8 16v.
Old 22-03-2006, 00:57   #6
Nick Cupra R
Cheers Mark, I'll have a look at the weekend and check the connections. I'll try and sort it out myself rather than having to call you up again
GTI 16v, I've only had the car a matter of weeks so am still discovering its "features". The fault code was definitely relating to the immobiliser and I have not had any of the problems you mention with the car. I'm pretty sure my problem is something quite simple such as a bad connection on the SEAT immobiliser. I know the dash has been of a number of times which makes it even more possible.
__________________
Old 22-03-2006, 19:52   #7
PbBooM
Posts: n/a
my 8valve did the same thing Pissed me off big time.Took it back to seat and they recoded the keys and its never done it since!!
Old 28-04-2010, 15:23   #8
gtikezz
Senior Member
gtikezz's Avatar
gtikezz has 10 points
dose anyone know the code for this ?
gtikezz is offline   Reply With Quote
Old 28-04-2010, 16:30   #9
M1KEH
M1KE
M1KEH has 10 points
You need your SKC Kez, then you need VAG-com.
M1KEH is offline   Reply With Quote
Old 28-04-2010, 19:34   #10
gtikezz
Senior Member
gtikezz's Avatar
thnks for the reply it was for a freind but it is sorted now somehow his ecu had been locked out or something
Reply
Bookmarks
« Previous Thread | Next Thread »
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
(View-All Members who have read this thread : 97
Alan_, Al_G, asmart01, auq, backus, badat_81, Badishi, Baxter, beavz_28, BirdDog, BPH, brad1002, bri-man, cb_safc, chris128, clarkey-cool/s, CORDY_SXMAN, cossie1, CraigW, Cupra Kid, cuprajose, cuprakemp, cupraspark, CupraTurbo20v, D1andonlyantman, DaneJD89, Dave_R, Donny9835, dtmwelburn, Emibuddedge, Finan, Fisher, Fl@pper, fresh_creps, gaffer1986, GJF47, Gorbachov, gregorcupra, griff82, grq, gtikezz, HoopDub, Hutton, ib04tom, jamesington, jamie8954, joanne wheel, Jodrell, Jonesy, Jonny95 SXE, K.S.D, K1Shane, karizma_fas, level_lewis, M1KEH, Mark_vRS, matty85, metroarmadillo, Mobo, NottsLCR, NWhiteley, oxo1fly, ozaudio, Pander, paul-murphys, paulhughes1009, Petecog79, Priezti, probee, pubsinger, pugparcels, QU4RESMA, R3k1355, roscupra, samacus, samc, Sandy1985, Scimitar, Seatmann, Shabobchik, sharif, Sile-R, sirjimalot, Speed-FReek, starosta, stephenSF, steve m, stolen, Street, supracupra, swedey21, thebody, uksteffy, uzi_cupra, wezy0, Wiggy20, xJib
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Ibiza FR problems? vinyldj Ibiza Mk4 4 30-01-2006 20:52
Website © 2014 SEATCupra.net
Disclaimer: SEATCupra.net is not an official SEAT site and is not affiliated to SEAT in any way. Visit the Official SEAT Website.
SEATCupra.net are not directly responsible for information which maybe posted in this forum.
All content is viewed and used at your own risk. We do not warrant the accuracy or reliability of any of the information.
The views expressed herein are those of the individual contributors and not necessarily those of SEATCupra.net or SEAT
All trademarks and copyrights remain property of their respective owners.
