ECU flashing tools
muddyboots
Still hanging around
Oct 16, 2002
5,739
Has anyone got any experience of using ECU flashing tools, such as this:
http://cgi.ebay.co.uk/KWP2000-ECU-F...049277636QQcategoryZ32094QQrdZ1QQcmdZViewItem
Looks intriguing. Is it quite straightforward to read & write maps to the ECU of a PD TDI ?
It's more for interest than doing my own remap, just be interesting to compare standard & remaps from different TDIs to see what kind of parameters actually get changed.
Any links to resources on mapping & map parameters would be interesting :)
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
Now you can be a tuner too :)
It's amazing how many people buy these & proclaim to be 'tuners' that arrive on these forums... 'cheap' but not as cheap as the original investment in unknown code.
muddyboots
Oct 16, 2002
5,739
LOL
No, don't want to be a tuner, just curious about what sort of maps are available in the ECU, and what changes the various remaps make to them.
So was looking for info on how easy these devices are to use, whether they contain everything I'd need to download & upload maps OK :)
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
quite possibley, the software is pretty easy to use.... connect to car, select approriate file, upload.
unlikely to be encrypted, but then it won't be supported either.
basstard
Dropping Cogs is Useless
Aug 24, 2002
2,746
Roma, Italia
for that I think you'd need some sort of remap software while that in the bid is just a reader/flasher if I got it right,,,
maybe you'd need stuff like alien or something similar,,,
muddyboots
Oct 16, 2002
5,739
I think it gives some ability to view and edit the maps, but how user-friendly it is, I don't know...
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
But it says "BRAND NEW KWP 2000 ECU Flasher + complete Software package + 30.000 ECU Tunning Files"
So it comes with files
you presume that all these 'tuners' do anything other than buy predefined files... even the so called custom mappers just do this.
Only a few pieces of software allow for adjustments - and if you don't have hacked versions, they're dear.
muddyboots
Oct 16, 2002
5,739
Do you reckon the "software" just allows you to upload & download files then, rather than tinkering with them ?
prc
Sooty Meister
I have one of those and it is usefull to flash cars, but I really don't know about the software...
really wouldn't want to mess around without knowing what to do with the maps. Most of the map editors I've seen for sale already know where the very basic maps are (most of the normal ones that get changed). It won't show know where any of the less used (but also important ones) are.
adaml
274
Leeds
Interesting this topic should come up now, I've been thinking about the same kind of questions. Just out of pure curiosity, I've no ambition whatsoever to write my own maps.
What exactly is a remap? People refer to getting a new "map", new "software" or "code".
Speaking from a background in software development these are different things. "Code" is a program or part of a program, i.e. an ordered sequence of commands which can include conditional branches and loops etc. A "map" is a table (or set of tables) of numerical values. Program vs Data.
If you take a program and you want to change its behaviour you can either hack into it and tweak variables or code conditions. Or you can totally rewrite it and add functionality.
So... at its simplest a "remap" could be adjusting the values in a few ecu tables, or at its most complex it could be a full rewrite of the entire engine controller code in the ecu. On that spectrum, where would most chip tuners fall I wonder.
muddyboots
Oct 16, 2002
5,739
m0rk said:
Do you know what you'd want to do with tinkering?
No. Just have an enquiring mind and want to see what kind of maps remappers tinker with :)
PRC -> Any info on map editors - are these easy to get hold of, or do they cost lots ?
muddyboots
Oct 16, 2002
5,739
Just adjusting values in tables, I doubt they rewrite any code.
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
Most will just adjust the torque/load request..... lets the ECU sort out the rest of what it needs.
EVC is pretty dear as editors go, but it's not 'obvious' how it works
prc
Sooty Meister
WINOLS from EVC I feel is best (or most powerful), but you'll need to know where the maps are. They won't sell the code to just anyone, and a cracked version will still cost over 1000 euros with only some of the checksums..
The easiest map read would probably be race2000 or whatever it's called now from Alientech. Still very expensive though.
A remap is usually just adhusting new values to what's already there. Usually fueling, boost, drivers wish (accelerator position) and the torque limiting tables are changed. About 8 total.
muddyboots
Oct 16, 2002
5,739
Had a look at the EVC site, but not much info unless you're registered, and you have to provide evidence that you work for a tuning company to do so :(
Shame because it seems to have lots of useful stuff.
