Badger5
Go Back   SEAT Cupra.net - SEAT Forum » Diagnostics, Tuning and Modification » Engine Discussion » Turbo Forum » Big Turbo Discussion
Big Turbo Discussion Big Turbo (and hopefully Big Power) discussion area GT28RS, IHI - what have you?
Reply
Thread Tools Rate Thread Display Modes
Old 20-05-2006, 17:32   #41
EddyH
EddyH's Avatar
EddyH has 10 points
Quote:
Originally Posted by caney
cheers mate! back on topic now though as eddy will shout at us
No worries it's all related and makes interesting reading.
__________________
EddyH
S8
A3 2.0TDI Sport
EddyH is offline   Reply With Quote
Old 20-05-2006, 18:32   #42
Songman
Songman's Avatar
Songman has 10 points
Apologies to Eddy - and a big thumbs up too! - can`t wait to see the results - should be fantastic
The standard pistons/crank are fine for 500 - just the rods are dodgy i`m told - I read that some of the Vortex guys have passed an incredible 700bhp now!!
Would think that the largeport head is advisable for big power
is anyone doing CNC porting of 1.8T heads in UK? -I know Cosworth are producing CNC jobs for Sub/EVO
__________________
J A B B A P O W E R
Songman is offline   Reply With Quote
Old 20-05-2006, 18:44   #43
EddyH
EddyH's Avatar
EddyH has 10 points
Unfortunately I think it's a bit late to go large port now as my head has already been sent off for matching to the valves, however the inlet valves will be 1mm larger diameter than standard.
__________________
EddyH
S8
A3 2.0TDI Sport
Old 20-05-2006, 19:03   #44
Songman
Songman's Avatar
Quote:
I`m sure the inlets on a ported smallport head will flow plenty enough - it would be interesting to see the flow data ported smallport/standard largeport
The theroists always worry more about flow capacity on the exhaust side - port/manifold/turbo/exhaust - any restriction there with big power outputs, and things get `difficult` - according to the flow data there`s not much difference between the exhaust ports in the two heads
__________________
J A B B A P O W E R
Old 21-05-2006, 09:58   #45
ibizacupra
Jack-RIP my little Friend
ibizacupra's Avatar
ibizacupra has 30 points
i've just bought this one and got it polished as well,much cheaper than the apr one!
Are you smallport or largeport Steve?
Dahlback does'nt port to largeport properly as the runners are very narrow still.
ibizacupra is offline   Reply With Quote
Old 21-05-2006, 10:11   #46
caney
caney's Avatar
caney has 10 points
hi bill,mine is still smallport got the mani off edd's sportec golf as he's having a custom one built by them
__________________
JABBASPORT 2.0T 534bhp/489ftlbs
caney is offline   Reply With Quote
Old 21-05-2006, 12:25   #47
ryan_s3
ryan_s3 has 10 points
Looks good for my up-coming largeport head with those graphs.
__________________
S3 335bhp @ Marlin ,now...
Ultimate Road and Track Evo
ryan_s3 is offline   Reply With Quote
Old 21-05-2006, 14:11   #48
caney
caney's Avatar
caney has 10 points
Quote:
so come on then ryan what BIG plans have you got for yours then?or is it all hush hush
__________________
Old 21-05-2006, 14:53   #49
ryan_s3
No big plans steve,thought i told you at pod what i was doing.400bhp max, probably a bit less.
__________________
Old 21-05-2006, 14:57   #50
caney
caney's Avatar
caney has 10 points
you've already got a bit less! 360bhp
__________________
Old 30-05-2006, 12:36   #51
EddyH
EddyH's Avatar
EddyH has 10 points
Update:
The pistons arrived last week, the block was sent off and has been bored out to suit the new pistons.
Rods arrived this morning.
__________________
EddyH
S8
A3 2.0TDI Sport
Old 30-05-2006, 21:51   #52
caney
caney's Avatar
caney has 10 points
Update:
up and running for gti?
__________________
Old 30-05-2006, 23:04   #53
EddyH
EddyH's Avatar
EddyH has 10 points
That's the plan but I think I may struggle to get it sufficiently run in to grace the strip but I'll do my best dependant on when it's finished.
Here's a photo of one of the 83mm JE pistons which I was sent today:
__________________
EddyH
S8
A3 2.0TDI Sport
Old 31-05-2006, 15:05   #54
Geeba
Newbie
Geeba has 10 points
Hmmm isnt this the same Edd that said "I like my ko3s and wont go big turbo?" Just gone HUGE everything!
Look forward to seeing it at the show...
Geeba is offline   Reply With Quote
Old 31-05-2006, 15:10   #55
EddyH
EddyH's Avatar
EddyH has 10 points
Yes.
Truth is though I'd tried IHI and GT28RS and they weren't for me. However I tried a car with a similar setup to what I'm going for and it just felt right, I knew straight away it was what I wanted for my car.
__________________
EddyH
S8
A3 2.0TDI Sport
Old 31-05-2006, 17:17   #56
ryan_s3
360bhp at 6100rpm then nosedive,
this time it will be 400bhp and held......hopefully.
I'll leave it too you guys for the big numbers!
__________________
Old 31-05-2006, 18:33   #57
caney
caney's Avatar
caney has 10 points
lovely lovely
__________________
Old 01-06-2006, 08:54   #58
ibizacupra
ibizacupra's Avatar
5 valve pockets
some higher lift cams?
wondering what CR from the crown of the piston.
shame you cant seem em when they're in the motor.
Old 01-06-2006, 09:20   #59
EddyH
EddyH's Avatar
EddyH has 10 points
The valve pockets also have me a little puzzled as the cams and crank are staying standard.
I agree it's such a shame that the pistons won't be seen.
EDIT: The cut outs are for use with high lift cams (which I won't have), the compression ratio is 8.5:1
__________________
EddyH
S8
A3 2.0TDI Sport
Old 02-06-2006, 09:44   #60
ibizacupra
ibizacupra's Avatar
swap ya!
Reply
Bookmarks
« Previous Thread | Next Thread »
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
(View-All Members who have read this thread : 29
16v6n, Allan_84, beattie17, boomsly, buch bdm 400, cav, Cupra R101, cupra_matt, dan.h, danfr, DaNnY_LaD, daves ibiza, EL, Ibiza sport man, in10sity, Jimmy-Boy, leons_ leon, lloydie, Matt S!, Mk2steve, ne11er, Northerner, oliver20, Olly_P, rudolf2, sheffboy, tarzan, Tom Duff, Vernon p
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Badgerwagen-Custom Code & JBS Auto Designs Sponsorship ibizacupra Badger5 62 27-03-2006 18:59
Filling the Car Up! Silver-Ibiza Ibiza Mk4 11 12-03-2006 12:53
A cautionary tale trks_dad TDi - SEAT Diesel specific topics 5 01-02-2004 22:33
Bridging the Generation Gap bazzer Leon Mk1 22 19-12-2001 22:04
Website © 2013 SEATCupra.net
Disclaimer: SEATCupra.net is not an official SEAT site and is not affiliated to SEAT in any way. Visit the Official SEAT Website.
SEATCupra.net are not directly responsible for information which maybe posted in this forum.
All content is viewed and used at your own risk. We do not warrant the accuracy or reliability of any of the information.
The views expressed herein are those of the individual contributors and not necessarily those of SEATCupra.net or SEAT
All trademarks and copyrights remain property of their respective owners.
