SEAT Servicing
Go Back   SEAT Cupra.net - SEAT Forum » SEAT Model Specific Discussion Forum includes Members Projects » Ibiza » Ibiza Mk3
Ibiza Mk3 For 2000-2002 Specific Information.
Reply
Thread Tools Rate Thread Display Modes
Old 07-08-2006, 07:16   #1
Bogwoppit
Bogwoppit's Avatar
Bogwoppit has 10 points
Boost Gauge, DV, FPR or green nipple?
Hello
I am just about to buy a X reg Seat ibiza Cupra 1.8 Turbo that has been treated to a Jabbaport remap (199.9bhp). The first modification I will be making is fitting Autometer Phantom Oil temp and boost gauges.
After reading various boost gauge fitting articles on this website, can someone please tell me the best point to take my boost readings from, top of DV, off the FPR or the green nipple on the side of the engine??
Many thanks
Bogwoppit is offline   Reply With Quote
Old 07-08-2006, 11:08   #2
jonesya3
jonesya3's Avatar
jonesya3 has 10 points
when i asked the same question afew months back i was told to put it to the green niple which i did and it works perfectly there mate
__________________
Fitted : Blueflame/Jetex Turbo Back, Revo Stage 2, Forge FMIC, TIP + 007 DV, Seat Sport Strut Brace, OZ Superleggeras, LCR Splitter, 6k HID'S, Brembo's, Drilled Brembo Disc's + DS2500 Pads, Eibach F + R Hubcentric Spacers, N249 Bypass, KW Coilovers, TT Short Shifter, Toyo T1R's,ECS N75, Jetex Filter, Spec 3 clutch and flywheel
jonesya3 is offline   Reply With Quote
Old 07-08-2006, 11:17   #3
David_smith_909
Smithy
David_smith_909's Avatar
David_smith_909 has 10 points
got mine on top of dv
__________________
Pearl white hybrid/NOS powered MK3 Cupra - Gone but never forgotten
Red Audi A3 Sportback
David_smith_909 is offline   Reply With Quote
Old 07-08-2006, 11:23   #4
Molehill_Mike
Rollin' on 20s
Molehill_Mike's Avatar
Molehill_Mike has 10 points
Tried Green Nipple, but I got alot of rattle via that route, now run off of FPR...with no probs
Mike
__________________
Current - Mk1 FL Platinum Leon Cupra Stg1 / Mustang GT
Previous - Stage 1 Leon PD150 FR+ / IHI MK3 Cupra / Stage II K03S MK3 Cupra / MK5 Eco SC / MK3 Cupra Std
Molehill_Mike is offline   Reply With Quote
Old 07-08-2006, 11:34   #5
karl.w
methanol junkie
karl.w's Avatar
karl.w has 10 points
i tried mine on the green nipple but had to change it to the dump valve as it was bouncing all over the place.
i think you just have to try it and see what happens
karl.w is offline   Reply With Quote
Old 07-08-2006, 11:36   #6
Molehill_Mike
Rollin' on 20s
Thing is from where I tried that green nipple thing, I now have a short piece of blue hose with a screw in the top of it and two tie wraps, it was a bugger to get that thing off, sliced and diced it, so no way it would go back on, I would run off the DV or FPR to be honest mate, but your choice of course
Mike
__________________
Old 07-08-2006, 11:42   #7
jonesya3
jonesya3's Avatar
yer its was a pain to take the cap of that green nipple from what i remeber but i dont get any rattle or bouncing and was told the green nipple was more accurate ?
__________________
Old 07-08-2006, 11:55   #8
TimD
TimD has 10 points
I'd take it off the dump valve personally..
Heres a scenario, you plumb the boost gauge into the FPR and at WOT )wide open throttle) if for some reason your T-Piece for the dump valve comes un done, what will happen?
The FPR thinks you have taken your foot off the throttle, but in reality it's wide open, would it lean out?
TimD is offline   Reply With Quote
Old 07-08-2006, 11:55   #9
claudefrog
claudefrog's Avatar
claudefrog has 10 points
i took my feed from the green nipple, i just removed mine with a pair of pliers and pulled it off, can go back on anytime i want.
i dont get any bouncing etc with taking my feed from there
claudefrog is offline   Reply With Quote
Old 07-08-2006, 11:58   #10
Molehill_Mike
Rollin' on 20s
I may have to try it agin then... just 'buzzed' alot thats all..
Weird..
Mike
__________________
Old 07-08-2006, 12:37   #11
PhilW
3071
PhilW's Avatar
PhilW has 10 points
Neither.
T-pieced into either vac hoses on the underside of the inlet manifold on the left hand side. Close to the side of entry into the car and replaceable unlike cutting the green nipple.
__________________
PhilW is offline   Reply With Quote
Old 07-08-2006, 19:33   #12
hadz
hadz has 10 points
i put mine on the green nipple to start and the needle in the boost gauge just went mad! so now i have got it into the FPR which i was told gives the best reading!
hadz is offline   Reply With Quote
Old 07-08-2006, 21:25   #13
Bogwoppit
Bogwoppit's Avatar
Many thanks for your replies.
Old 07-08-2006, 21:28   #14
minxycov
Posts: n/a
don't like the sound of this green nipple melarky......did a quick search on the net - and there are some scary pics......
Old 08-08-2006, 01:05   #15
Craig!
IHI Ibiza Cupra
Craig!'s Avatar
Craig! has 10 points
Same as others, been on the green nipple but have since moved it into the top dv vaccume line and it works beaut, real smooth!
__________________
VAG Cars - www.vagcars.co.uk - North East VAG Owners Club
Craig! is offline   Reply With Quote
Old 08-08-2006, 08:34   #16
Molehill_Mike
Rollin' on 20s
Do you guys think running it off the FPR is less accurate than the DV then?
I might swap mine about see if I get a smoother reading...
Mike
__________________
Reply
Bookmarks
« Previous Thread | Next Thread »
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
(View-All Members who have read this thread : 20
-pseudonymous-, Alex Cupra, czaki, Dan Watts, daves ibiza, Dougy, jammin, K'DO, Klang J, Mustii, ndbrgr, Norregaard, Pingu101, rabcupra, ReC]<, redcupraboy, repsolbladedaz, s1l3nc3r, SeanyK, stuy
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
boost gauge vibrating? flashbsd Ibiza Mk3 9 20-05-2006 18:52
Boost gauge, Sisson TDi - SEAT Diesel specific topics 24 30-10-2005 13:24
Ticking boost gauge... help!!! J@mes Leon Mk1 14 01-06-2005 22:16
Boost Gauge Newbos Ibiza Mk3 4 30-12-2003 18:04
Boost gauge readings? campbell_p30 Modifications and Tuning 8 24-08-2003 13:26
Website © 2013 SEATCupra.net
Disclaimer: SEATCupra.net is not an official SEAT site and is not affiliated to SEAT in any way. Visit the Official SEAT Website.
SEATCupra.net are not directly responsible for information which maybe posted in this forum.
All content is viewed and used at your own risk. We do not warrant the accuracy or reliability of any of the information.
The views expressed herein are those of the individual contributors and not necessarily those of SEATCupra.net or SEAT
All trademarks and copyrights remain property of their respective owners.
