K03s logs
-pseudonymous-
681
After recent problems with my car, i decided to bypass the N249 valve today to see if things would improve.
Here are some logs i did tonight with settings set at B8T7 on the sps3. As some of you will know im running a k03s and stage 2 Revo with all the goodies....
Any comments would be much appreciated!
Cheers Ollie.
-pseudonymous-
681
thanks for the comments lads....
I dont think Ibiza's read as high as Leons on the MAF's for some reason, somebody correct me if im wrong.
The MAF was only replaced just over a week ago so have no idea why im still getting lowish readings. That log was done in 3rd gear though, could that be why?
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
Yeah - you should use 4th or 5th if your car can pull it.
work it out as a percentage though 10g/s in 170 isn't too shabby..... that's only just over 5%
-pseudonymous-
681
Yep i actually was quite happy with the MAF readings to be honest as i was only seeing around 150g/s tops before. I actually logged blocks 115 & 118 in 4th gear but ran out of track lol
What do you guys think to the other logs? Look ok? The requested boost still seems a little low dont you think?
Thanks.
Jay
86
france
Visit site
Cheers Ollie.
is the maf the only change between the new logs and the logs in this topic ?
because the n75 duty cycle is now a little lower with a little higher achieved boost :)
your midrange requested boost seems low to me for a B8 setting, but i think it's due to the stage2 remap which is different from stage1, i've also change from stage 1 to 2 recently but haven't yet log it a lot :lol:
-pseudonymous-
681
Hi Jay. I think the first logs on that link were on stage 1 revo with a 3bar fpr and settings at B6 T7.
Maybe i could knock the boost or timing up 1 notch now as im not seeing any timing retard at all at B8T7...
Jay
86
france
Visit site
i know the first logs were done with stage1, but you seem to have a little higher boost and little lower n75 duty cycle so i was asking if the maf was the only hardware "air related" modification ;)
