airbag light on after taking out fuse
shav4life
hi,
today i used my kwp2000+ tool to extract the map files from my ecu,
i did that seccessfully then exited the application, unplugged the cables and put ignition off.
now before i did all that i had fuse 5,11 and 25 taken out.
after i put ignition off i put the fuses back on but now the airbag light has come on.
when i put ignition on the light comes on, goes off for around 2-3 sec and comes back on again.
any idea what part number the airbag controller is in a leon cupra 2001 Y reg? because vag-com advices not to scan the controller if its the ones which gets damaged by having them scanned.
thanks,
Phillc
Love is....Yellow
Apr 23, 2007
4,170
20
Pershore, worcestershire
I have had this to after changing my interior and when i changed the clocks but reset it with vagcom anyway both times :rolleyes: no probs at all, mines a 2001 X, Cupra by the way.:D
shav4life
your brave!!
i am thinking if i damage it thats like £100 atleast to replace. and am kind of short on budget at the moment.
what version of vag-com did you use? and any idea what part number your controller was?
thanks,
Phillc
Love is....Yellow
Apr 23, 2007
4,170
20
It is the 311/2 Version, sorry i did'nt notice which controller it was.
I just got fed up with the light on all the time. I have now only got the acceleration and yaw light to sort out
shav4life
thanks for the info, i appriciate it.
will try it in a bit and get back to you.
