225/45-17's?
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
be tight i would think
205-40-17 used to catch the rear liners on mine on a 7j rim with weight in and nowhere near that low
depends on the offset of course
marccowley1
57
tis what i thought, i've got 16's with 195 45 16 on and fancy something a bit more comfortable! Lol ps got a spare set of 17's im refurbing hence the original post
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
dropped from 205/40/17 down to 195/45/16 and now on 195/50/16 for a little more comfort
17's I found a litte harsher
using 225/45/17 i dont reckon you'll get em in past the rear sill edge to be honest - damn close with mine as it is
back in a minute - gonna measure :):)
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
my 195/50/16 have about 20mm clearance to end of the standard sill (not inc sideskirts)
a 225/45/17 as above has 24.7mm more on the radius than mine and with the extra width on top gonna be realllly close before you even think of ride height + speedbumps etc
killer205
206
no they wont fit i had to put "15 wheels on mine and mine is lowed 60mm on coil overs it bent all my wings out on the front
DONT TRY IT
R3 NDD
65
redcar
i have 215/40/17's on mine but with 205/40/17 tyres, lowered about 60mm and it rubs a bit on full lock and when i have 3 people in the back. appart from that its fine. spose yours are an extra 10mm wide! plus i dont know the offset of my wheels.
AusCupra
51
Wexford
Lads just thinking about going the 17 inch route on my Cupra. Sounds from this post as it wouldn't be worth it? Should I just stick with the current 16's. Have a set of Coilovers for it to go on...
Currently it sits at standard height on standard suspension!
R3 NDD
65
redcar
well mine sits like this on 215/40/17 (with 205/40/17 tyres) lowered about 60mm. it rubs on the back when i go over big bumps but only when i have 3 people in the back. and it ever so slightly rbs the chassis when its on full lock. only noticed when i took the wheels off though. nothing noticeable:)
