What you putting in the search box.. cant find anything other than mark 5/6 panels![]()
I've searched
The only thing I can suggest is that you keep searching that and sorting by 'newly listed'.
Cheers mate, when I bought the RNS facia I gave David at Sere my VIN and he just matched it for me. Would be nice if it comes the in the correct colour!
Yeah.. but that could be where the difficult job starts. The silver/pearl color used on the FR & Cupra pre facelift models is not available anymore on the new facelift model. They got new interior codes, like black, the matt aluminium look you see on most FR/Cupra models and the 3rd is the one i got. I think its called black/silver galena.
Basically this means its hard to get a new style climate control fascia surrounding in the old colors used on the Pre-FL model because they didnt ever make it in this color.
Oh right, I see what you mean.
Did you have to get the rns fascia and cluster surround to match the climate control facia instead then?
Hmm.. I'm thinking Gloss Black or Carbon maybe?
Fitted mine today
I think I'd like to change the grey fascias to piano black to match the RNS and Climate Control, and then change the plastic around the dials to white. Just a thought!
Did you have to change any wires around in the back when fitting the facelift unit? Or change any coding in VCDS? Because the facelift unit is always off when I turn the car back on.
Climatronic Wiring
On A Connector (black) extract both; Pin 16 and Pin 20 and put Pin 16 on the place were Pin 20 was, leave the wire on Pin 20 loose (not connected to the harrnes) for later connect the Air Quality Sensor if needed.
If you have an older VW Model you will need this wiring change:
Motors in parallel:
On C Connector (brown): Pin 7 connected to Pin 10 and Pin 8 connected to Pin 9
On B Connector (black): Pin 6 to Pin 7
Hi want to do this mod as ive just bought heated seats since i broke my driver seat in th fr but cant find the SEAT climatronic panel with th heated seats settings, so i then spotted this with VW panel how did u find the fascia to go round it tho?
Well i have just been looking on ebay for it with no luck, not even th new style without heated seats might just have to w8 untill it comes up
Agreed leon wins on looks again, where would i get it priced new just a local dealership?
Can you get these direct from SEAT as the new one looks awesome and I cant find any on the web, also I take it you have to get a lower bit to match.
