LCR. This FMIC?
ReDBull
Every day's a school day.
Nov 21, 2006
2,991
14
Lincoln
Where have you fitted the reducers? At the charge pipe and plastic map sensor pipe, or either side of the IC?
DOLBY
2,934
98
North of London
www.facebook.com
Reducers go either side of intercooler. Obviously you need 2 good jubilees either side to keep these in place. Not some cheapo ones either. I used 'murray' clamps from SFS. Expensive but not something you wanna skimp on due to boost leaks etc.
Then after the reducers it's all 63mm to charge pipe etc. :)
Sent from my iPhone when I should be working....
swedey21
Most days i drink meths..
Nov 15, 2011
441
burford
45 Degrees are needed off the intercooler...unless you want it hitting all of the front bumper..
see below..
ReDBull
Nov 21, 2006
2,991
14
Lincoln
I wasn't planning on replacing the map sensor pipe is that the best way of doing it? Is the the Forge one you're using?
swedey21
Nov 15, 2011
441
burford
No easy way is using the standard map pipe.
I've used a forge one,so I can tap into the alloy pipe for my WMI.
swedey21
Nov 15, 2011
441
burford
Just to confuse you...
IF i wanst fitting WMI..i would have used..
Intercooler (using76mm pipes)
2x 45 degree 76-63mm reducers silicone
2x alloy 90 degree pipes
1x90 degree silicone hose
1x 45 degree silicone hose
2x small alloy connecting pipe
1x 90 degree silicone hose
that way you can replace the standard pipe off the metal charge pipe with a silicone one..
The map sensor etc on the other side stays standard..
hope it makes sence!
swedey21
Nov 15, 2011
441
burford
So to use WMI it's best to fit the forge pipe?
Unless you want to tap into the metal pipe off the intercooler outlet..
Ive done it like that,as i had already fitted the I/C and didnt want to wait for it to get a blob of alloy for the jet fitted,that and i wanted to relocate the D/V.
I brought the forge pipe,sent it off to be welded,then installed it..that way the car wasnt off the road.
ReDBull
Nov 21, 2006
2,991
14
Lincoln
I'm planning on fitting WMI so I'll have to decided whether to fit the forge pipe sooner or later.
ReDBull
Nov 21, 2006
2,991
14
Lincoln
It sounds like the 63mm cooler has been discontinued. Where in Lincolnshire are you?
ReDBull
Nov 21, 2006
2,991
14
Lincoln
Are you up for a meet on the 27th at the pride of Lincoln? Hopefully it's going to be a monthly thing around Lincolnshire. There has already been a Hull meet. Would be good if you could make it.
Laggo
171
Linconshire
yeah im down for that, just give me an address and a time. Got many people going?
