are there any other intercoolers out there apart from the £670 forge ones is there somthing a little bit cheaper ?
fastest 1/4 mile set with (modified) factory intercooler.
Pace products do them too
Bear in mind that the polo/fabia have a different IC to the ibiza so unless Pace have developed another one for the ibiza since I think your stuck with stock.
At the OP I remember two guys on here identical cars, remaps, exhausts had a go against each other @ GTI International. One of the guys had an uprated cooler the other was stock.
Both cars made 5.6second launches so very comparable yet the one with the IC pulled away a fair amount once they were in 3rd gear......no coincidence I think...
Then later blew its engine![]()
i had a look at a different forum and it looks like you have to take your car to them and they custom make it for your car they do a IC and radiator combo for less then a grand and drops the temp of the engine by at least 30-40c
My early (Oct 2009) Cupra came with weak pistons, faulty injectors and the wrong sparkplugs, + a over-rich cold start map = blown engine. Thanks SEAT. Plenty of standard engines have failed, but only I have had to pay for a rebuild, so I got a proper job done. I believe I will match my best time again in the right conditions.Not totally true, I'm sure both are "to blame" so to speak. Imagine fitting a massive turbo on an engine witg a small intercooler. You could say the turbo/mapping blew it up, And you'd be right but if the intercooler was big enough to cope it might not have happened, or happened as quick.
Pace polo/fabia fit I no because I purchased Hurdys![]()
It's onto a standard radiator mate. I'm after just the intercooler aswell but as said before they come as a package.
