Well, I have an issue with the way my R has been running for well over 12 months now (hence not having stretched his legs for ages
) & he's now in the 4th garage who have finally found "issues":
there is play in turbo
breather pipes are gunged up with a mix of oil & water which has been being fed into my engine instead of air,
my head gasket has gone
intercoolers are full of oil
the manifold is also cracked & needs replacing
...most of this appears to be due to the idiots at the stealers not having a clue on the dozen occasions I've taken him back & told them I had a running issue & think it's air related so can they check the pipes, only to be told that their's nothing wrong, they think he's running great for his age & if its not broke don't fix it![Furious [:@] [:@]](/forums/styles/seatcupra/oldforumsmileys/furious.gif)
Jonny is the original car used for the press releases of this model, I have a set of showroom boards with him doing his modeling job
...so, he's quite special & question is... .. is he worth repairing & can anyone help me source cheap or used parts to save this special fella ???
PLEEEEEASE... I need the following:
I've been quoted £1957
for parts & £700 for labour!
-Details of somewhere (reliable) where I can either pick up a recon Turbo or get mine inspected & rebuilt
-2 breather pipes from the cam cover & oil filter housing which meet at a T piece
-replacement manifold
-Turbo inlet pipe
-Head gasket set
-Head bolt set
-Timing belt & damper set
-Water pump
- Oil filter
-Dip stick tube
Also could do with a pair of rear springs & an uprated shock mount kit (inc bearings & bushes)
Any help will be much appreciated, thanks peeps
-Turbo inlet pipe
-Head gasket set
-Head bolt set
-Water pump
- Oil filter
-Dip stick tube
