tyre pressures, what one would you trust?
red line fun
602
12
Scotland
i've had this tyre inflator for a few years now and it's always served me well. my most recent sent of fronts (3rd or 4th set since i bought the car) started to wear on the outer edges. i was confused as the pressures were showing okay (so i ruled out under-inflation) so i started to think the issue maybe lay elsewhere e.g. tracking/alignment or steering component problem. however the tyres looked low pressure wise.
so i bought this pressure reader from halfords and was shocked when it read something like 29.5 and 30.5 on my fronts, the michelin one was reading 33. i therefore inflated the tyres until they were reading 33 on the halfords device even though this now meant they were reading something like 35/36 on the inflator.
that was two weeks ago, checked them today and the michelin inflator was reading 34 whereas the halfords device was saying 31.5 for one and 32 for the other. so i've again inflated them so they read 33 on the halfords device even though the michelin inflator has to be set to 35/36 to get them to 33 ... if that makes sense?!?
i'm assuming the halfords device is correct (michelin inflator is giving a false high reading e.g. saying they're 33 when they're maybe 31 or 30), would you agree? regardless of what one is actually accurate, it's quite a big discrepancy between the devices.
martin j.
1,997
894
Fife
Forecourt tyre inflator so/gauges should checked for calibration regularly and have a report sticker on them, if you can find one that has been done recently use that to check the accuracy of your guages?
Personally I too have one of the Ring units that I got from work, 3 of us got one each at the same time so I tried them all on a sample tyre and got the same reading from them all across a range of pressures.
PAULTDI67
307
sheffield s.yorkshire
Hi GUYS yea I bought same pressure guage as red line's got&checked&my compressor(one o them things what runs off fag lighter socket but ther's no fag ligter:lol:)reads same:)on similar kind o thing how does &when tpm work sudden loss o pressure(puncture)cos I've got a pressure guage 2 check&not sure how accurate it is cos I've dropped it a couple o times so I bought http://www.halfords.com/motoring-tr...es/halfords-digital-tyre-pressure-tread-gauge as auto express test rated it top 4 accuracy now set all tyres 2 32psi wi old guage what I thought was right now reset tpm checed wi Halfords jobbi they was all diff'rent:confused:
kazand
Is powered by Medtronics
Jun 6, 2010
4,138
73
Brum
Tyre monitoring works via ABS sensor, it checks rotation of wheel. Flat tyre = smaller rolling radius= faster rotation compared to others=light on. Summat like that anyway. Fiendishly clever these Germans/Spaniards/Czechs....... :)
PAULTDI67
307
Thought it was summat like abs sensors BUT what pressure difference? cos like I said when I checked wi Halfords guage all tyres were different pressures:confused:
HFStuart
18
The gauges on the home compressors are only usually accurate when the compressor is not pumping. You should stop the compressor to check the pressure. I'd trust the Halfords digital one more.
Take it to a main petrol station and check it against their gauge if you want to be sure.
FWIW Some of the most accurate gauges are the decent mechanical ones with a needle - simplicity has it's virtues.
Stuart
