Hi guys,
Just thought I would ask a couple of quick questions regarding the DRLs and sidelights on the Leon mk3.
When DRLs are activated they are at full brightness? Is this correct I have also activated the rear DRLs too to work in line with the fronts. When the headlights are on the DRLs dim slightly?
However when I activate the sidelights manually they are exactly the same as the DRLs, they do not dim at all. Should they dim to the same brightness as if the headlights were on? I am slightly confused in the point in sidelights if they serve the same purpose as the DRLs? Obviously they would usually switch on the rear lights and number plate lights but I have that already activated? Any ideas guys?
