The steering feels slightly heavier than I think it should but other symptoms are sometimes when turning it feels tight then a little knock and it feels like it frees itself.
I had a loud squeal on full lock but when I replaced the Air con compressor I turned the belt inside out which stopped that.
The steering wheel has gone off straight and I've noticed wear on the outer edge of the NS front tyre. As a way of eliminating things I took it for a wheel alignment check and they said it was too far out on the NS to be just tracking.
I've looked under and all the bushes seem good, nothing looks damaged and a crowbar couldn't find anything obviously loose.
I do recall whacking a kerb a few months back on that side.
Could the damage be in the steering rack? The fluid level is fine but have noticed a little misting on one joint.
