2012 leon fr
Jun 10, 2020
8
Had my car for a month now and spent 1800 pounds trying to repair problem which is still there when I get into 3rd gear around 1900rpm the full car shakes violently in that gear and upwards this week I have had new engine mounts new driveshafts new luk flywheel and clutch injectors have been tested and are fine had it mapped back to standard but then had to map again as I didnt no it hadn't a dpf went to clean egr but that was blanked off also car is getting the rite amount fuel pressure I've also serviced the car bought new tyres and had wheels balanced been in 5 garages and everyone is scratching there heads andone help me
Leeoncupra
764
191
Halesowen
Has it been hooked to Vag comm? Or data logged
Jun 10, 2020
8
How long ago did the judder start? Did you buy the car from a dealer or private
I bought the car private but had delivered didnt realise it had a judder until I got on to motorway around 3rd gear upwards seems to fade out at 2500rpm
Leeoncupra
764
191
Halesowen
I'd be on your mans case who you bought the car off if his done you up like a kipper
Have you tried a vag specialist?
Jun 10, 2020
8
It was through facebook and can no longer contact them and yeah he says engine is 100percent he says must be drive transition related as if something is not balanced
Leeoncupra
764
191
Halesowen
Yeah that guy has definitely done the dirty what a *****
Sure someone on here can help
So first and second drive perfect up to redline but 3rd and above are juddering?
Jun 10, 2020
8
Yeah ano absolutely gutted spent another 180 yday if a hammer car and stay away from the rev range 1900 to 2500 car is smooth and lovley but if a go into them revs range the full car judders really violently no noises tho
Leeoncupra
764
191
Halesowen
Could be the remap
Who did it?
Jun 10, 2020
8
I had it mapped back to standard last week drove a couple days made no difference but then had to remap again because has no dpf in which I didnt no about
Jun 10, 2020
8
Definitely from the engine? You've pushed the clutch when it happens and coasted?
Yeah even if u let go of acclartor it goes away seems to be wen under load done absolutely every thing apart from gear box but goes in gear lovley no noise smooth
R3k1355
1,787
251
Yorkshire
So in gears 1&2 there's no problems?
3rd gear at 1900 it's shaking like mad?
4th-6th what happens?
Driving on the motorway at 70mph, knock it out of gear and coast in neutral and it's rattle free right?
Might be looking at a gearbox replacement
Jun 10, 2020
8
No rattling what so ever and every gear after 3rd shakes like mad but seems to fade out at 2500rpm goes away
