Mar 25, 2023
Hello,
I have Leon FR 2.0 TDI 135kw but without shift paddles on steering wheel.
Is there any option how to retrofit shift paddles?
Thank you
Yes, change the steering wheel to one with paddles, and code it in with VCDS. You need to check that the steering column controller fitted will support the paddle change.
I did this on a 2011 Skoda Superb 1.8TSI DSG, took less than an hour to do
Hello,
I have been looking to do this retrofit for my golf 6, how would I go about checking that the steering column controller will support the paddle shifter steering wheel?
Take a vcds scan of the car and cross reference the part number of the steering controller with the compatibility comparison list on the Ross Tech website
Hello,
I did that on my 2013 Leon FR. Bought second hand steering wheel with paddle shifters and it was just plug and play for me. Nothing needed to be coded on the car, it recognised it straight away and it works perfectly.
It costed me arround 70 pounds off Ebay. Without the airbag, of course :)
which surprises me a lot. Normally the gateway should recognize a multiple installation. because it would have to be coded in the gateway
