Install additional options for Cupra Formentor
pivko11
46
25
So, Full Link activated, works perfect. Total cost was 280€.
However, during activation an Airbag error appeared. Not sure what is the problem, but some replacement part was ordered so next friday I am going in for a replacement.
I asked them to also check for an infotainment update because of the occasional restart. I hope I get it.
pivko11
46
25
Resolved the Airbag issue, infotainment updated to 1940.
So far, everything works OK.
In car store app doesn't work though. It reports some error.
The cupra connect app on my iphone says I should renew the online services in the shop.mycupra.com
There it says that the store services are only available in the new My Cupra app or the in car store (which doesn't work).
The my Cupra app says that my car is not compatible with the My Cupra app and that I should use the cupra connect app :D
Edit:
The in car store now works, but no option to renew online services...
Nice...
12
Edit:
Nice...
That's the same issue I've had with the store/app, how did you get it working?
pivko11
46
25
I tried it a couple days later and it worked. But the only thing available is the cubic telekom.
If I wanted to buy the cupra connect, I honestly would not know how...
Aug 4, 2023
12
Oh okay, sounds like yours is the same as mine then.
My understanding is the store should have access to various other apps, not just connect and Cubic (my link to Cubic doesn't actually work either if I select it.)
Jul 3, 2024
FYI, I ordered the Full link activation just the other day. Total cost 270€.
I am scheduled for installation on friday.
You did it through the app or in person? also where? Was the car originally croatian or german for example? @Naxterra same questions :). Because i am also in zagreb, so any info would be great!
pivko11
46
25
My car is "Croatian", it was done at Porsche Interauto Cupra service by them.
I think that it is done through the Infotainment, but probably some service mode so I don't think you can do it yourself.
When I picked up the car, I had an activation code in a DVD box in the car (no DVD, just the code).
The Full Link app exists in the infotainment, but it needs to be activated.
P
Reactions: DiegoCruzs
P
It’s done via the OBD port using ODIS
