nd-photo.nl
4,655
647
The Netherlands
youtube.com
On a dutch Seat Forum there were a couple of instances of engine failure, which were pointing to an earlier revision fuel hose. When I bought the Leon Cupra in December last year, this was one of the first things I replaced. Luckily, after tapping some fuel, no rubber residue was found.
If your fuel hose consists of 2 pieces, its safe to say you have an earlier revision. Costs of the new hose are about 70-80 euro if I remember correctly
Partnr: 06K133986HF
Pics:
AP1GczPvnnMThFbWChv-2Wp_cwg2kjoq_m_kG1HWrqYbik58HvfcnT2O_6ULE4PWk2V91YOCIoygCtRKAK7iTjNHuOptDumPp4-qoiSxn-Z4QgQIE72p9hs1wJUjycj7unNZsDWRYv91gzASg2i4ENSTLW16lQ=w1920-h1080-s-no-gm
AP1GczM1IFLsB_z9cvzXqu4nwG_BRzLyxVF3tTZ3ontHW0FKiRZCAjuoFZOSowCduCGak72_qSMhipZBTsEl4da2oMosSqELUMjWh3XVnObnWd6WPTdbs-fRSBs2mpdfwpBZPJ6z2bvzBD4JgVnkjCtTJVWqfw=w1920-h1080-s-no-gm
The old revision is a 2 piece design (see bottom left corner)
AP1GczODF3se6FItuvU5hsCGhNOd15WyOErVn3xG0O4EYAFlXHMplEyj4f-fIs1OcdZf_OHAZSBMPXwvNgoP3yrIYQUvV71HFUnNBSZ9jhcPc_yV053J0K5SDkb7YXNudJcLYFgdekTcKUmUkR0Isec_ObZYxw=w1920-h1080-s-no-gm
The new revision is a 1 piece design
AP1GczPTJZ4Lpewo_tpMOiGCiZl3YJNsx1jtrQLGw2pkeAxyppaZct0d3VImoKAl_CBvm2_bri6_nhCddua4Ep_SSAJWV3tlI9v4UKo3ApbPR968Xwq1l_3MMrIEo2i3n14sXKUIgQIk6ysLg1qsM1LcAlnxSQ=w1920-h1080-s-no-gm
Partnr: 06K133986HF
Pics:
geometry dash scratch
Great! This guide is what I'm looking for. I'm replacing the coil packs, and while I have everything apart, I ordered the bracket on the side wall where the fuel lines clip in. I'm also planning to order the fuel line and filter.
Reactions: nd-photo.nl
