Heating Related Question
Havok316
Boost Junky
Jun 6, 2006
1,220
Weston-super-Mare
Hi im not sure if its the unit or there is a purpsoe to it, but in the morning i turn the heater onto the windscreen the heat set to HI the AUTO and AC appear on screen but i cant turn off AC or AUTO but if i turn the heater to FEET then turn it back i can turn them off. im not sure if its me or the unit.
gavthelad
Bring on the Boooooost
Nov 19, 2005
1,394
Redditch (Midlands)
ive had this a couple of times when the air con wont turn off, only lasted a minute or so on each occasion and has never happened since.....ive noticed you cant run the air con if the temp falls below 3 degrees/or if the frost sign appears but i would imagine this to be a safety feature in case part or all of the gas in the air con is frozen?
Havok316
Boost Junky
Jun 6, 2006
1,220
Weston-super-Mare
sounds like it could be that as it would make sense but ive had the ice symbol appear like this morning it was *0.5 and yesterday it was *0.0 and the aircon came on full blast but the windows was iced over.
