Another rattle, but from the rear
langy
99
Has anyone else noticed a rattle from the rear of there Leon, mine is currently bugging the cr@p out of me. It sounds as though its the rear passenger seat belt tensioner. I have been in the back, hit and tried moving things about, but no joy.
Please shed some light, otherwise i'll have to make a trip back to the dealer :doh:
Tam
Santa in disguise :)
Feb 10, 2005
1,777
Near Reevo :)
Spare wheel - either needs screwing down tighter or the tools under it need moving a bit (i believe!)
Rob66
1,633
97
UK
Langy
Pull both the rear seats forward. You'll see the retaining clips attached to the bodywork that the seats slot into. Wrap the metal clip (its a u shape) in insulation tape - give it 2 or 3 layers and put the seats back - you may have to slam them into place now - but it will solve any squeaks and the seats can still be lowered no problem.
Rob
langy
99
I had a rattle at the rear of my Cupra the other day.. Didn't shut the boot properly though. :doh: :D
My rear wiper wasn't working once, and the cure was the same :doh:
Rob66, I'll give that ago when I get home.
TIA
Rob66
1,633
97
UK
Good luck with it, pretty sure thats the solution its been mentioned a few times on here and worked for me. I would do both sides as well.
The tape just reduces the space between clip and seatback and removes the rattle - -flipping annoying though.
Let us know if it works.
Rob
re rear wiper not working - -i did exactly the same thing:whistle:
warren_cox
Back from the dead
All VAG's seem to rattle. Even the S3 has started to rattle now its got a few miles on it.
One from behind the stereo, and one from the boot where I swear they have taken the interior trim off the inside of the boot hatch to fit the number plate retainers as it doesn't fit that well to the metal of the boot lid. Drives me nuts but I'm trying to accept it as part of life.
cupra2007
RCOTY
Jan 7, 2007
193
rhodes/greece
i have my cupra for 2 months now.these are the rattles i came across so far:1)from the locking device of the boot.it needed a small arrangement from the dealer. 2)little strange noise came from behind that i thougt was coming from the passengers rear door.it prooved to came from unter the car!!it was the 2 rubber things that hold the exhaust in the middle of the car and they were a little loose!!the sound was something more like metallic!3)something metallic coming from the boot only sometimes.i wiil check it and report back.:)
wurzel
600
East Anglia
Try the door catch, my passenger rear door started rattling on catch.
Temporary fixed with insulation tape round striker, since then dealer has tightened catch. It sounded like seat belt tapping or something knocking inside rear door.
Stealthdave
298
had mine since xmas and can only hear rattles when music is foff, which is hardly ever so have left them
coxxic
160
CZ
www.absolutsystem.com
its definitely door lock (front door, but sounds like from rear doors ),i have had same problem on my FR ....
langy
99
I taped up the clips last night, but haven't been out and about yet, i'll find out later this afternoon on the weekly pilgrimage to Tesco. I'll post up and let you know.
belgarion
Cupra07
Mar 13, 2007
102
Waltham Abbey
Talking of strange noises.. Anyone opened both the rear windows and left the front windows up traveling about 40/50mph? Did this last weekend and not sure what it does exactly, but there is a loud bass noise at the rear.. Sounds like the boot is gonna come off! Try it..
langy
99
Rob,
Well a combination of tape around the rear seat retaining clips and around the clips for the rear doors has cured the problem :funk:
Thank you for the advice :clap:
Sean
