How to enable confirmation beep when locking/unlocking **GUIDE** with Video
Elliot29
379
This is a guide on how to enable confirmation beep when locking/unlocking using VCDS.
You need to check "bit1 & bit4" to enable the beep when locking and the beep when unlocking. My version didn't have the labels like shown above, so I just enabled those two bits and hoped for the best :blink: and it worked.
So to get to here you need to press "Select Control Model" on the home page
then press the Central Electronics Module -09
then Coding -07
then Long Coding Helper and ok the error that comes up.
Navigate to Component: BCM PQ25 on the drop down box
The go to Byte 5 and tick bit 1 & 4
Save the new coding and that's all :D
This is how it sounds on my Boca:
http://www.youtube.com/watch?v=WFwxnOmsWOU
Hope this helps :D
jc_boc
Missing the CUPRA R!
Jul 18, 2008
9,303
7
Desborough
Well done mate!!! 10/10 for that. So who is the London area that can hook me up with this neat little trick?!
ayc1985
29
i've alrwayds wondered about audible alarm sounds, but I get worried about the neighbours if I come home at2am or something!
What other options can be enabled via the laptop? Anything worth having?
MattBoc
Does anyone know if you can get this done around the lincoln area
tournado
28
TN22
Anyone know if the dealer will do this as I dont have the software to do it myself - or anyone local in Notts to do it for some beer tokens?
Shivy
VCDS guide to change electronic features on 6L Ibiza 58
Hello,
Is there an extensive manual/guide that shows all electronic feature we can change/modify on a 6L type Ibiza 58 with VCDS, please ?
thank you
