how do you remove the front drivers side ABS sensor?
fuey
i wana go faster
Jan 12, 2004
437
north west
uk.geocities.com
I had a look/go at it this morning.
I removed the bolt from the side, scraped away some rust, but the thing wouldn't pop out the back (used plenty of wd40).
Am I doing it right?
Also, if someone knows of the correct method, can the same technique be applied to the passenger side ABS removal?
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
wd40 it all up.....
I have to do it tonight, but basically - soak in wd40, undo the allen bolt, wiggle it free.
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
I think they might be handed... I can't remember
normally brutality is best, the casting corrodes v easily
fuey
i wana go faster
Jan 12, 2004
437
north west
uk.geocities.com
plugin section
the bent sensor section (hence needed replacing)
