Hi peeps. Ive recently fitted a ko3s and milltek DP & sports-cat to my ibiza cupra. It holds boost alot longer and higher up the rev range and sounds awesome. The problem is i only see the boost peaking at about 17psi whereas before it was peakin at just over 20psi. Is this normal or do i have a problem somewhere?
I did a few logs this morning which hopefully will shed some light on my problem...
Also the maximum reading im seeing from the maf on block 003 is 151g/s which seems a tad low to me, but i have always had low readings even after changing the maf for a new one. Im currently running revo stage 1 set at boost 6 timing 7.
Any help or opinions would be much appreciated!
Cheers ollie.
Cheers ollie.
