¦¦ Proffitt's Black Cupra Turbo ¦¦ - *MOT passed / Tints...on or off?? pg4*
Molehill_Mike
Rollin' on 20s
Jan 3, 2005
2,566
Bedfordshire
Not being rude here, but thats not true, look above at my pics... no resistors, but black box is gone. Mine was all done with just tubing.
As far as the car was concerned the box was still there :)
Looked much cleaner :)
Jan 6, 2009
1,102
sunny falmouth
Right after a little bit of reading on the forum and looking at pic i though i would have a go Bypassing the N249.
Well, what can i say....for all the threads on here about it...its a piece of cake. lol
Though i would mess it up but no, its nice and simple...followed a thread on here and walla. All done.
Soo some pics:
Before:
After:
Also when i opened the bonned i could hear this hissing sound, was like this since i got it but i couldnt hear it while i was looking around the car before buying!! ohwell.
Any way, i automaticlly though...Split Pipe [:@]
Had a look around from where the noise was coming from and:
BINGO!!
Now after:
Sounds a lot better AND its running at around 18psi of boost :clap:
Although it only boosts to about 14/15psi sometimes in different gears! Is this normal for the psi to change?
AND now on idle the boost gauge is now showing a different reading, is this normal??
After i fixed it:
With the split, it was on about 10 / 9.
Also, would like to ask...is my DV on the right way? :redface:
Im not 100% sure as im a n0000b :whistle:
Any advice would be awesome thanks.
alright bud looks to me that your dv is the wrong way around give it a try the other way.
as for your boost gauge thats looking about the same as mines does on tick over.
does your psi drop from 14psi if 14 is your peak, mine peaks at 21psi and then drops to around 16psi then holds it and thats in all gears iv got a stage 1 remap not sure who maybe revo
Proffitt
134
Conwy
Some inspiration:
*Hope the guy who's car it is don't mind me using the pic*
Going on holiday on monday and getting a Wash and Wax mobile cleaning to come and give her a full valet as the guy i bought it off didnt [:@]
So im getting a full valet inside and out.
will get pics of before and will get after ones :)
Righttoe
100% Welsh *******
Jul 21, 2008
220
Bexleyheath, UK
From your pic mate your dump valve is on correct. It looks slightly different to a 007 but same design. The pipe leading into the bottom of the valve should be coming from the charge pipe. The shiney alloy pipe running across top of engine! Which by the looks of yours it is. This means the charge from the turbo will be pushing up on the piston and will open it when accelerator is let off. The outlet on the side of the valve should then go into the tip.
If it was installed the other way around it would still work. But all the pressure is pushing on the side of piston and it won't open as responsively
Proffitt
134
Conwy
Small update:
Taking plates off to clean the bay up a little.
From this:
To this:
BUT went back to this:
Due to this:
Ya see the big bit of metal the bolts goes through, well that acts like a fat ass washer and i couldnt be arsed to cut it so i left it on :y: lol
Then i got carried away with taking things off....
Will let the pics do the talking:
TO
TO
TO
Proffitt
134
Conwy
And i took my DV off to clean and to turn it around.
Also wanted to see what make it was...
TO
TO
Back Fitted
O and its a Forge, which i was pleased about.
Comments?
Molehill_Mike
Rollin' on 20s
Jan 3, 2005
2,566
Bedfordshire
Looking good mate, I like it :)
I had those coil pakcs (the bolt down ones) mucho better than standard... shame you're leaving the tray on, but it looks better :)
Love the clean look, keep it going fella :)
Mike
Proffitt
134
Conwy
Cheers Mike :D
I didn't know i had them untill someone the other day pointed it out. What difference do they do? lol
Molehill_Mike
Rollin' on 20s
Jan 3, 2005
2,566
Bedfordshire
Well the standard ones 'can' work their way out, slightly raised. Plus the standard ones are'nt great, during ownership your almost guaranteed to need to repalce a couple (I always carried a spare).
The IHI had the ones like you've got, had no problems with them :)
Mike
Proffitt
134
Conwy
Met up with Sam (Sams_VTR, from saxperience.com) last night and went for a small photoshoot.
Locations (if you know North Wales):
The tram station up on the Orme
Then went to Colwyn Bay underground lorry loading bay
Im not taking any credit for these, they were all taken by Sam
Anyway, less talking and more pics...
Tram station:
