¦¦ Proffitt's Black Cupra Turbo ¦¦ - *MOT passed / Tints...on or off?? pg4*
Proffitt
134
Conwy
Right after a little bit of reading on the forum and looking at pic i though i would have a go Bypassing the N249.
Well, what can i say....for all the threads on here about it...its a piece of cake. lol
Though i would mess it up but no, its nice and simple...followed a thread on here and walla. All done.
Soo some pics:
Before:
After:
Also when i opened the bonned i could hear this hissing sound, was like this since i got it but i couldnt hear it while i was looking around the car before buying!! ohwell.
Any way, i automaticlly though...Split Pipe [:@]
Had a look around from where the noise was coming from and:
BINGO!!
Now after:
Sounds a lot better AND its running at around 18psi of boost :clap:
Although it only boosts to about 14/15psi sometimes in different gears! Is this normal for the psi to change?
AND now on idle the boost gauge is now showing a different reading, is this normal??
After i fixed it:
With the split, it was on about 10 / 9.
Also, would like to ask...is my DV on the right way? :redface:
Im not 100% sure as im a n0000b :whistle:
Any advice would be awesome thanks.
Molehill_Mike
Rollin' on 20s
Jan 3, 2005
2,566
Bedfordshire
If its a 007P then it makes more of a squeak, rather than being quiet...(depending on CAI). Not sure if you can fit ALL types in both orientations...
Those PSI levels lookmucho better mate, is what I'd expect from a stage 1 map.
Which N249 thread did you read?? ;)
Mike
Proffitt
134
Conwy
Mike
I dont have a clue what DV i actually have. Will have to take it off one day and look for markings.
I read this thread - N249 ByPass Guide Although i did read / look at about a million threads on here :D
Molehill_Mike
Rollin' on 20s
Jan 3, 2005
2,566
Bedfordshire
A trick I used to do if I developed a fault, or hit limp mode, was to reset the battery. You won't lose the map, but it will reset the cars 'learnt' settings. Will be worth a go if its been driving at 5psi and poor vac for a while.
Could be a Bailey DV30, that was the most common after a 007P. The reason I say this is I had both a polished 007P and a black 007p, neither had 'ridges' around the top as per your pic. Also, bearing in mind it was a couple of years ago, I don' think my DV sat like yours does... let me find a pic.. :)
I only asked about the N249 thread as I started one years ago, and every so often it pops up! lol
Mike
EDIT: Pics
Proffitt
134
Conwy
Ahh right, well i most probs looked at yours. So thanks :) lol
O, is it worth changing mine around then?
What will happen?
Molehill_Mike
Rollin' on 20s
Jan 3, 2005
2,566
Bedfordshire
I'm not saying that, but worth looking at other peoples when you're next at a meet.
At the end of the day if you are driving around fine, and no error codes are apparent, then the car is happy, and so should you be lol
Mike
