1.4 TSI engine noise (Video Included)
MJ
5,619
54
Manchester
What's your service history like? How olds the car? What's the milage? Did you buy it from seat?
J400uk
1,978
London, UK
Sounds like the familiar noise of a failing chain/ tensioner I'm afraid. As you've only had it a month I'd suggest going back to the dealer purchased from. Not a cheap fix unfortunately
bigbadjay
1,670
26
North Manchester
After the first 2 - 3 seconds it's sounds fine and drives perfectly, no issues at all, good fuel economy and performance
Have a search on YouTube for similar videos. I'm sure there are worse sounding tsi's. It sounds a bit whiney over a normal noisy tsi
Sent from my HTC One using Tapatalk
mark88
18
It doesn't sound bad to me? Sure its not just with it being chain driven its taking a few seconds for the oil to flow round and reach the components, hence the slightly louder noise dying away after 2 seconds? At the end of the day, the oil can't be everywhere within a split second of turning the key if its all drained into the sump overnight.
mark88
18
Good good,! They're always going to sound louder and more metallic than a belt driven engine, but at the end of the day its a hell of alot more robust than a belt also! People get far too worried about chain driven engines, but the service interval is more than double that of a timing belt which obviously says something. I've owned two cars previous to my current that have been chain driven and I've never had a problem at all! Just make sure you check and change the oil regularly and you'll be fine.
bigbadjay
1,670
26
North Manchester
Stop it MJ!
What is the actual service interval/procedure. How much do seat charge?
I'm a looong way off still 30k
