Hi all,
I'm having a fault occuring with my 1.6tdi ibiza...
The glow plug light is flashing (not all the time) but only turns off when the engine is turned off..
The EML is now lit ( this is easily cleared with an OBD reader )
The obd reader shows error P2454 'Diesel Particulate Filter Differential Pressure Sensor circuit low'.
I have had a look at the pressure sensor & it seems to be ok, no sign of scorching from exhaust heat. Are these prone to fail... or is it just a sign of another problem i.e. the dpf?
I understand the pressure sensor measures the soot content of the dpf by measuring air pressure before and after the dpf.. but on my car only one of the tubes is connected.. the other is fitted with a short pipe to nothing?
The reason I mention this, is because I have read somewhere that the pressure sensor needs to be reset with vcds before it's first use - but I'm puzzled when one of the pressure pipes is open to the atmosphere..
Any help would be greatly appreciated
John
John
