chopper
Can anyone tell me how or where the speedo gets its reading from? The speedo suddenly stopped working so I thought there must be a problem with the sensor located in experience on top of the diff housing. When I checked this there was a cable going to a blank dummy fitting that sits in the hole for where the normal speedo sensor sits [Normal as in 02J/02A style boxes]. How dose this system work? I am suspicous that it works off the ABS speed sensors and that there maybe a fault with the ABS.
Thanks in advance.
Thanks in advance.
