Recently obtained the above, clutch bite is on floor and judders a little getting into gear. Drives and selects all gears fine but a little crunch with first and reverse. Bled the clutch first, appears the previous owner may have rounded the nipple. The thing wouldn’t pressurise for toffee so changed the master and pressure bled it. Considerably better pedal but bite is still real low. Also first quarter of pedal travel is very light. I should probably change the slave too (luckily this engine it’s external) but if no bubbles in the bleed kit line then I presume the nipple isn’t leaking. What would be the next point of call. Starting in 5th or in gear with handbrake in stalls car instantly and I don’t think this has a DMF, if it does it isn’t making the noise some do. One last point, there’s a tiny spot of oil on the drive directly under where the clutch housing meets the engine. Please help
